11-16-2017 11:14 AM - last edited on 08-10-2022 02:52 PM by Paul Zimmerman
Standalone Mode -
Cisco Wireless Gateway for LoRaWAN Software Configuration Guide - Cisco
Virtual IOS Interface Mode -
11-16-2017 11:46 AM
Please be noted the commands related to “packet-forwarder” in this guide only work on Actility LRR, not other vendors’ packet-forwarder.
11-20-2017 08:20 AM
Hi Jun Wen,
I'm working with the IXM-LPWA-800-16-K9 LoRa gateway, where:
The system version is:
Corsica Software, Version 2.0.11, RELEASE SOFTWARE
Copyright (c) 2012-2014, 2017 by Cisco Systems, Inc.
Compiled 18-Sep-2017.16:19:04UTC-07:00 by Corsica Team
ROM: Bootstrap program is Corsica boot loader
Firmware Version : 2.0.11, RELEASE SOFTWARE
Bootloader Version: 20170515_cisco
cisco model: IXM-LPWA-800-16-K9
Processor : ARMv7 Processor rev 1 (v7l) with 1027308K bytes of memory.
The FPGA versione is:
INFO: SPI speed set to 2000000 Hz
checking FPGA version...
FPGA version: 58
HAL version: 5.0.0
SX1301 #0 version: 103
SX1301 #0 chip ID: 1
SX1301 #1 version: 103
SX1301 #1 chip ID: 1
##PASS: FPGA version check OK
The packet forwarder version is
PublicKeyStatus : Installed
FirmwareStatus : Installed
PacketFwdVersion : 1.8.19
LRRID : 68ba4729
PartnerID : 0001
If I perform the following command (from configure terminal):
packet-forwarder start
or
packet-forwarder restart
I have a Radio issue.
17:46:21.404 (1825) [../lgw_x8.c:733] RADIO configured
17:46:21.404 (1825) [../lgw_x8.c:755] RADIO starting ...
17:46:21.404 (1825) [../lgw_x8.c:760] BOARD0 RADIO cannot be started ret=-1 'Invalid version number for the top FPGA'
So the packet forwarder doesn't start.
How could I solve this issue?
Regards.
11-20-2017 10:27 AM
Please read the release notes of 2.0.11 for LRR support version.
11-20-2017 11:59 PM
Hi Jun,
no I didn't.
I found this packet forwarder version on the cisco gateway. I didn't perform any kind of upgrade.
How could I upgrade the pktfwd to the lastest 2.2.46?
best regards.
11-21-2017 12:12 AM
Hi Ivano,
We would expect that you receive Thingpark LRR package through your standard channel.
If not, please, send me an e-mail, I will forward you a no-config LRR package.
Patrick
11-21-2017 09:41 AM
Our software image never pre-install any LRR from manufacturing. No idea how you got this unit with LRR pre-installed, it is abnormal.
