CML personal VM problems
andrewcode3
I am trying to get my VM up and running and I am encountering an error
Virtualized Intel VT-x/EPT is not supported on this platform. Continue without virtualized Intel VT-x/EPT?
Hyper V is disabled  (see attached)
Core isolation is off
Any ideas what to try next?
What hypervisor are you trying install install the CML VM on? Vmware or Hyper-V (not officially supported by CML)? Is this Windows 10 or 11? If Windows 11, did you upgrade from Windows 10, or was Windows 11 already installed on your machine?
Virtualization must be enabled on the CML host machine. With either Windows 10 or 11, you will need to enable VT-x in BIOS. Additionally, if you upgraded from Windows 10 to 11, Virtual Machine Platform may not be enabled. See Enable Virtualization on Windows 11 PCs.
Disclaimers: I am long in CSCO. Bad answers are my own fault as they are not AI generated.
Assuming Vmware is your HV, there is a similar thread on learningnetwork.cisco.com:
https://learningnetwork.cisco.com/s/question/0D56e0000DRnM7vCQF/vtx-support-issue-on-the-cml-26-on-vmware-workstation-17-player
I am trying to use VMware in a win 11 machine.  I have enabled virutalization and it still does not work.
rkochery
Hi, Please try the steps in CML troubleshooting FAQ item # 12
https://developer.cisco.com/docs/modeling-labs/#!faq/troubleshooting
