forwarding rate, forwarding bandwidth, and switching bandwidth
nejsha.arba
dear All
i face one of IT PEOPLES
they need to see forwarding rate, in Cisco 2960+24TC-L switch
on Cisco datasheet its available and can be seen
the people need to see based on Cisco command  on enable mode or global mode? i search many commands but i can't get any that can show us the exact forwarding rate measurement 6.5MPPS
any one that know how to know this p/s?
ARUN
dont know you are still looking for answer
he switching forwarding rate= ports number × corresponding packet forwarding rate of ports.
The packet forwarding rate for gigabit port=1,000,000,000bps/8bit/(64+8+12)byte=1,488,095ppsPps is short for packets per second. Because we use 64 bytes per packet as the test standard of packet forwarding rate, and the 8 bytes are for the frame header. The 12 bytes are for the frame interval.
So for the gigabit port, the packet forwarding rate is 1,488,095pps=1.488Mpps. And for the fast ethernet port, the packet forwarding rate is 0.1488Mpps.
On ES-4124, there are 24 fast ethernet ports and 4 gigabit ports.
The switching forwarding rate=0.1488Mpps*24+1.488Mpps*2=6.54Mpps
vote helpful and mark solved if it helps
Arun
