ā01-19-2017 11:14 AM
I have a problem in attached scenario(vlanscenario.zip)
In this scenario Vlan1 is management(native) vlan on all switches.
There is 2 defined vlan: vlan2 and vlan3 on all switches
Inter switches links are trunk
There is 2 unexpected problem in this scenario
1.the laptop connected to the hub can receive ping requests from vlan 2 in all floor(it should drop it because the packet is tagged using .1q)
2.pings from vlan1 in all 3 floors are received successfully by vlan2 in second floor .
I use packet tracer-7.
Thanks in advance.
ā01-19-2017 11:40 AM
Attachment not opening!!
ā01-19-2017 12:14 PM
The .zip file contains .pkt file which is created using CiscoPacket_Tracer_7.0_build_201_X64_GEEKBOY.IR.exe
I checked it again and it seems there is no problem with file.
ā02-06-2017 11:01 PM
HI!
can you please try to send the config files..
if it possible try to send your topology ..
thank you
CRaju
ā06-12-2017 09:18 AM
Hello, I just see your packet tracer,
The laptop "mg21" of vlan 2 that is located in the second floor has the same IP address than the laptop which is connected to the hub (laptop 11)
1. Actually the laptop from the vlan 2 in the second floor pings to itself
2. pings from vlan1 in all 3 floors are received successfully by laptop 11 in second floor.
So I recommend you to change the addressing for vlan 1 or vlan 2 to a different network segment.
Greetings!!
