Surface Pro 4 Microphones
slimura
Can someone please tell me if Proximity works using both microphones located on the surface pro 4? It has one microphone on the front and one on the back. The front mic is covered when the surface pro 4 is in the dock. The back mic is not blocked while in the dock.
Just want to make sure that proximity is listening using both microphones in situations like this.
Sal
Magnus Ohm
I have not tested this but do you have a surface pro 4 available and are able to test if it still pairs when its in the dock compared to when its not? That should give you at least some idea, feel free to share you experiences as well. :)
Someone else here might be able to tell you if its using both mics or only one.
/Magnus
