3650 upgrade help
primeinc
This 3650 switch is in install mode and still takes 12 minutes to boot . Running 16.3.7.  Its a single switch and I have the priority at 15.  It acted the same at priority 1.  It hangs for 6 full minutes at the arrow below.  And, as soon as I'm able to logon, a show ver says it's been up 7 minutes which would be great if I had been able to logon 7 minutes earlier.  Is there anything I can do to improve the boot time?  What is it doing for the 6 minutes at the arrow?
thx
Tom
6 Replies 6
primeinc
Here is the entire boot log.
3650-24# show log
Syslog logging: enabled (0 messages dropped, 1 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
Console logging: level debugging, 44 messages logged, xml disabled,
filtering disabled
Monitor logging: level debugging, 0 messages logged, xml disabled,
filtering disabled
Buffer logging: level debugging, 44 messages logged, xml disabled,
filtering disabled
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: disabled
File logging: disabled
Persistent logging: disabled
No active filter modules.
Trap logging: level informational, 47 message lines logged
Logging Source-Interface: VRF Name:
Log Buffer (4096 bytes):
EL_INFO: HMAN-IOS channel event for switch 1: EMP_RELAY: Channel UP!
*Oct 9 13:39:47.223: %STACKMGR-1-STACK_LINK_CHANGE:Switch 1 R0/0: stack_mgr: Stack port 1 on switch 1 is nocable
*Oct 9 13:39:47.223: %STACKMGR-1-STACK_LINK_CHANGE:Switch 1 R0/0: stack_mgr: Stack port 2 on switch 1 is down
*Oct 9 13:39:47.223: %STACKMGR-1-STACK_LINK_CHANGE:Switch 1 R0/0: stack_mgr: Stack port 2 on switch 1 is nocable
*Oct 9 13:39:47.223: %STACKMGR-6-SWITCH_ADDED:Switch 1 R0/0: stack_mgr: Switch 1 has been added to the stack.
*Oct 9 13:39:47.223: %STACKMGR-6-ACTIVE_ELECTED:Switch 1 R0/0: stack_mgr: Switch 1 has been elected ACTIVE.
*Oct 9 13:40:10.013: %HMANRP-6-EMP_NO_ELECTION_INFO: Could not elect active EMP switch, setting emp active switch to 0: EMP_RELAY: Could not elect switch with mgmt port UP
*Oct 9 13:40:10.052: %LINEPROTO-5-UPDOWN: Line protocol on Interface Lsmpi18/0/3, changed state to up
*Oct 9 13:40:10.063: %LINEPROTO-5-UPDOWN: Line protocol on Interface EOBC18/0/1, changed state to up
*Oct 9 13:40:10.063: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0, changed state to down
*Oct 9 13:40:10.064: %LINEPROTO-5-UPDOWN: Line protocol on Interface LIIN18/0/2, changed state to up
*Oct 9 13:40:13.097: %IOSXE_MGMTVRF-6-CREATE_SUCCESS_INFO: Management vrf Mgmt-vrf created with ID 1, ipv4 table-id 0x1, ipv6 table-id 0x1E000001
*Oct 9 13:40:14.469: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
*Oct 9 13:40:22.441: %SYS-6-CLOCKUPDATE: System clock has been updated from 13:40:22 UTC Tue Oct 9 2018 to 07:40:22 CST Tue Oct 9 2018, configured from console by vty0.
*Oct 9 13:40:22.443: %SYS-6-CLOCKUPDATE: System clock has been updated from 07:40:22 CST Tue Oct 9 2018 to 08:40:22 CDT Tue Oct 9 2018, configured from console by vty0.
*Oct 9 13:40:24.738: %LINK-5-CHANGED: Interface GigabitEthernet0/0, changed state to administratively down
*Oct 9 13:40:32.738: %HMANRP-6-EMP_NO_ELECTION_INFO: Could not elect active EMP switch, setting emp active switch to 0: EMP_RELAY: Could not elect switch with mgmt port UP
*Oct 9 13:43:11.993: %PNP-6-PNP_DISCOVERY_STOPPED: PnP Discovery stopped (Startup Config Present)
*Oct 9 13:45:58.873: %SYS-5-CONFIG_I: Configured from memory by console
*Oct 9 13:46:02.994: %LINK-3-UPDOWN: Interface Vlan1, changed state to up
*Oct 9 13:46:04.582: %PLATFORM_PM-6-MODULE_INSERTED: SFP module inserted with interface name Gi1/1/3
*Oct 9 13:46:04.591: %SYS-5-RESTART: System restarted --
Cisco IOS Software [Denali], Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 16.3.7, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Fri 03-Aug-18 23:49 by mcpre
*Oct 9 13:46:04.610: %PLATFORM_PM-6-MODULE_INSERTED: SFP module inserted with interface name Gi1/1/4
*Oct 9 13:46:04.691: %SSH-5-ENABLED: SSH 1.99 has been enabled
*Oct 9 13:46:05.128: %SNMP-5-COLDSTART: SNMP agent on host 3650-24 is undergoing a cold start
*Oct 9 13:46:06.811: %SYS-6-BOOTTIME: Time taken to reboot after reload = 666 seconds
*Oct 9 13:46:08.220: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/2, changed state to up
*Oct 9 13:46:09.227: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/2, changed state to up
*Oct 9 13:46:35.311: %SSH-5-DISABLED: SSH 1.99 has been disabled
*Oct 9 13:46:35.313: %SSH-5-ENABLED: SSH 1.99 has been enabled
*Oct 9 13:46:35.435: %SSH-5-DISABLED: SSH 1.99 has been disabled
*Oct 9 13:46:35.441: %SSH-5-ENABLED: SSH 1.99 has been enabled
*Oct 9 13:46:39.237: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to up
3650-24#
5 to 7 minutes - this is normal.
You already changed  priority so this is best you can do.
BB
Leo Laohoo
Is there any reason for running 16.X.X?
I am asking because I'd recommend 3.6.X.
Leo,
per my Cisco SE, he recommended moving to Denali as the 3.x code was planned on being phased out and Denali would be the long term code. My lifecycle management has included this code and all new switches are being put into production with 16.3.7 as there is a PoE bug in 16.3.5b that we are hitting.
What PoE bug ?
The PoE bugs are CSCvj76259 and CSCvd46008.
These bugs only appear on 3650/3850. These bugs have been first observed on 3.6.X and all the way to 16.X.X.
Unfortunately, this is not just a software bug but a hardware defect with the 3650/3850.
