10-06-2020 12:20 AM
I have a two locations running ASA5525's as cluster in each location. They run a S-2-S VPN between them & replicate some database info using Mirroring.
If I switch Master/Slave then the DB Mirror reports as down. Initially this was suspected to be due to a lack of NAT IP's allocated to the Cluster. I resolved this & the NAT error messages stopped, but mirror problem persists. I have added reverse route injection to the VPN & set it to be NAT exempt, but still get these mirror broken messages.
Any ideas ?
10-06-2020 02:38 AM
we need some more information, how your configuration and high level diagram how they conencted.
post the complete logs here.
10-06-2020 02:46 AM
Wait one, turns out whilst testing this this morning one of the DB servers was doing updates & mirror was broken, so it may be OK. I'll post an update once the DB team have fixed their issue & we have tested again.
10-06-2020 07:44 AM
So after further diagnosis the issue appears to be caused by a differential MTU size between the Master and Slave. When Unit B is Master it provides an MTU of 1436 from DB1 to DB2 for the replication. When Unit A is made master this drops to an MTU of 1358 & traffic fails.
Checking both ASA's they have MSS set to 1380, so slightly concerned that the path via one FW is below this & the other is above it.
Any ideas greatly appreciated.
Cheers
