ASAv always use Private Ip of Outside interface for IpSec negotiation
sudsark
Hi Team,
I'm encountering an IPSec VPN issue between a Cisco Router and Cisco ASAv
(hosted on AWS EC2) and would appreciate your guidance.
**Environment:**
- Peer 1: Cisco Router (on-premises)
- Peer 2: Cisco ASAv on AWS EC2
**Issue:**
The IPSec tunnel establishes successfully (Phase 1), but during Phase 2
negotiation, the router detects the ASAv's PRIVATE IP instead of its PUBLIC
IP for identity matching.
**Current Behavior:**
- Router peer configuration: Uses ASAv's PUBLIC IP (Elastic IP)
- Phase 2 negotiation: Router receives ASAv's PRIVATE IP as remote identity
- Result: Identity mismatch causes negotiation failures
**Workaround Found:**
Modifying the router configuration to either:
1. `match identity remote any` (less secure)
2. `match identity remote <private-ip>` (works but not ideal)
For example :  in the below router configuration I had to update "match identity remote any" instead point to the public ip itself , also this will work if I update any to --> private ip of the asa.
Since I have some restriction on my migration project since customer wants seamless migration without doing any changes in eft side routers , and with their current setup between cisco routers Ipsec ( not asav ) this phase2 also working over public ip of the router  , I am exploring how can i address this with new architecture in AWS.
**QUESTIONS:**
1. **ASAv Configuration:** Can ASAv be configured to advertise its EIP as
identity instead of private IP?
2. **Platform Alternative:** Would Cisco CSR1000v (Virtual Router) behave
differently than ASAv in this NAT scenario?
3. **AWS Architecture:** Are there alternative AWS networking approaches
(VPN Gateway, Transit Gateway, etc.) that avoid this issue?
4. **Documentation:** Is this a documented limitation of running ASAv behind
AWS NAT? Any Cisco/AWS guides on this migration pattern?
5. **Real-world Solutions:** Has anyone successfully migrated router-to-router
IPSec to AWS without modifying the remote peer configuration?
Please sugegst.
Ben Weber
Hey @sudsark
You should be able to define the identity of the ASAv under the IKEv2 profile. You should set the EIP with identity address {ipv4-address} under the profile configuration. AFAIK this should override the default setting for NAT to advertise the private IP.
The CSR would behave slightly differently, you can use a public EIP and therefore don't need to worry about NAT-T.
On whether AWS recommends using native services, it is recommended to use vpn-gw or tgw for native IPSec termination (which bypasses the need for NAT).
Some helpful sources:
Cisco ASAv RA-VPN on the AWS Cloud
Configuring Internet Key Exchange Version 2 (IKEv2) and FlexVPN Site-to-Site  [Support] - Cisco Systems
Configure Site-to-Site IKEv2 Tunnel between ASA and Router - Cisco
Solved: IPSEC- Match identity address with NAT-T - Cisco Community
- BW
Please rate posts if they have been helpful.
Thanks @Ben Weber  I will try the IKEV2 profile setting, i did try earlier but its only giving me option to set the default outside interface privste ip , no option to set public Ip ( EIP of the NAT instance) as the identifier in ASAv. Now i got into ao different go live requirement but test this out again and update you.
We are not going with AWS native solution here due to limitation which wouldn't resolve all the use cases customers need.
