Client-side timeout/auto disconnect
Cji912
Community Member
I was wondering if there is a way to set up an auto-disconnect in AnyConnect after a fixed session time, or idle time from the client side. I know this is possible from the server side, but can users set up their own auto-disconnects?
vpn-session-timeout <time> <<- this command under the group-policy will end the session after specific time
Configure a maximum amount of time for VPN connections, using the vpn-session-timeout command in group-policy configuration mode or in username configuration mode.
hostname(config-group-policy)# vpn-session-timeout {minutes | none}
The minimum time is 1 minute, and the maximum time is 35791394 minutes. There is no default value. At the end of this period of time, the ASA terminates the connection.
