取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
FAN LOW RPM LOGs ON ROUTER 2800
navsaljo76
Hello Community,
This is the IOS on router : (C2800NM-ADVIPSERVICESK9-M), Version 12.4(25g)
logging discriminator command is NOT available.
Is there any other way to disable a FAN LOW_RPM logs without changing the severity level for the entire group?.
I would like to disable those, but don't see an option to specify the text to only target those logs.
sh env all
Main Power Supply is AC with -48V
-48V supply status: OK
-48V relay status: NON-ISOLATED
Fan 1 OK
Fan 2 Low RPM
Fan 3 Low RPM
Jan 31 05:25:08.307: %ENVMON-4-FAN_LOW_RPM: Fan 2 service recommended
Jan 31 05:25:08.307: %ENVMON-4-FAN_LOW_RPM: Fan 3 service recommended
Thank you in advance for your assistance
2 条回复2
Leo Laohoo
2800 are notorious for the fans to throw up these error messages.
The error messages are not "false negatives" and they are legit.  The fan assemblies are just "sensitive".
Power down the router, remove the fan tray assembly and clean it.  That should, temporarily, fix the issue.
I know this is old but it keeps coming up on a Google search, better to read:
https://community.cisco.com/t5/routing/how-to-block-fan-messages-in-router-syslog-buffer/td-p/1525590
