First time post Cisco CML 2.6 in place upgrade
ranhell3d
I just installed the in place upgrade and managed to figure out sever issues but I'm stuck on this one error message.
"11:17:29 iosv-0: Failed to choose a suitable compute node (cml-controller is administratively disabled.)"
I'm not sure where to find how to enable cml controller.
if I could get some help that would be very appreciated.
5 Replies 5
Mark Willis
I would check that the CML is still licensed, and if not, reapply the license.
I did that twice all is green and is showing properly working and registered.
Thank you for replying to my post.
By default, the upgrade puts the system in a "maintenance mode", with the compute node in a "Registered" state, both new to the 2.6 release. Do you have banner near the top of your CML dashboard that says "Planned System Maintenance"? If so:
Tools --> System Administration --> Compute Hosts
Select your compute node and change admission state to "Ready". Being able to deny new labs starting up is new to 2.6
Tools --> System Administration --> System Maintenance
Disable maintenance mode. Being able to put the system into a maintenance mode is new to 2.6.
Disclaimers: I am long in CSCO. Bad answers are my own fault as they are not AI generated.
Hi Ramblin Tech,
"the upgrade puts the system in a "maintenance mode","
I figured that one out took me a minute but I did that part already.
computer hosts is set to online I will change it to ready.
I Will post my results in a bit here.
looks like that did the trick Ramblin Tech.
Thank you for your help very much appreciated saved me a reinstall from scratch to CML 2.6.
