Highlighted
Help Needed For Cisco 340 Edge
Not 100% sure If I am putting this in the right place. I have been trying to figure out how to change the admin password on cisco 340 edge so I can install a different OS. I need to enter the BIOS settings and change the admin password and turn off safe boot (If that's a thing). The manual is not very helpful. I will attach the manual. Any help would be very useful thank you.
1 ACCEPTED SOLUTION
Highlighted
Hall of Fame Community Legend
3 REPLIES 3
Highlighted
Highlighted
Do you know what the default root and reimage passwords are? Thank you for your help.
Highlighted
The default login credentials are found in the link I've posted.
