NCS540 USB boot Problem
selim521
Hi collegues. via USB boot i  faced with the following problem .
1. Unzipped ncs540-usb_boot-7.7.2.zip
2.Created Usb bootable Flash card with file (included EFI and Boot file in a root folder)
3. try 3-4 another vendor USB &  another usb ports NCS 540
but I couldn't be happy with what I saw.  Usb Boot failed.
Then i try boot iPXE via tftp. it looks like the file has been downloaded  successly. But not load  ncs540-mini-x-7.7.2.iso file .Anybody have troubleshoot for this?
proziumwtf
Is your device N540L or N540X, because if so, you would need a different software image, one can assume, this would be the problem...
proziumwtf
