I'm trying to write an API command to unmute the codec after firing the API mute command. I'm on firmware version TC7.3 (Cant update due to conflicts with other systems). The command "xCommand Audio Volume UnMute". Will work on occasion but most times it won't. However when it doesn't I can see it flash very briefly on the "Call Control" page volume bar, as well as get the correct Terminal response.
"xCommand Audio Volume unmute
OK
*r AudioVolumeUnMuteResult (status=OK):
** end"
Its the same result I get with the mute except for unmute instead of mute. But Mute will actually work while unmute wont.
Update:
Ok, in digging into this issue I discovered this command in the api guide "xCommand Audio Volume SetToDefault". But it lists it for both as a way to set what the new "default" is, as well as for unmute. However even with the codec set to 60 if I enter the api command to set it as the new default, then mute the codec. When I go to unmute it by telling it to go to the default using the same command it goes to the old default of 50. What am I doing wrong?
