WLC 3504 K9 Speed issue
sathyajith
Hi Guys,
We have WLC 3504 and 26 APs connected. We are experiencing issue with the speed on Wi-Fi it only goes 70 Mbps but on LAN it goes above 700 Mbps. Is there anything to be done on the WLC to increase the speed or any configuration to be done which I am missing.
10 Replies 10
Leo Laohoo
Many factors can affect the result between "70 Mbps", such as:
1.  What wired speed is the AP connected to, 10-, 100-, 1000 Mbps
2.  What radio was this "70 Mbps" connected to
3.  Configuration of the WLC
4.  Wireless client capability.
5.  And many others.
The most common reason we see a wireless client only capable of 70 Mbps are:
1.  The wireless client is an old and the best is can do is 70 Mbps
2.  Connected to 802.11b with one radio
thank you, Leo, for your reply as checked all the APs are on 1000 Mbps port. let me further investigate with the radio settings.
As I checked it's connecting on 802.11ac radio is there anything else to be checked?
Not important.
What is the model of the wireless NIC used to test this "70 mbps" and what is the wireless NIC driver version?
Hi Leo,
AP model: AIR-AP1852I-E-K9
NIC: Intel(R) Dual Band Wireless - AC 8265
Drivers Version: 20.70.25.2
this was used for testing but even the macs are also showing the same speed.
Connect the wireless client to WiFi and post the complete output to the command "show client details <MAC ADDRESS>".
If the AP connected to a Cisco Catalyst switch, post the complete output to the command "sh interface <PORT> controll".
(Cisco Controller) >show client detail bc:d0:74:63:db:db
Client MAC Address............................... bc:d0:74:63:db:db
Client Username ................................. N/A
Client Webauth Username ......................... N/A
Hostname: .......................................
Device Type: .................................... Unclassified
AP MAC Address................................... 04:5f:b9:fd:91:a0
AP Name.......................................... SSC-AP-FF-17
AP radio slot Id................................. 1
Client State..................................... Associated
User Authenticated by ........................... None
Client User Group................................
Client NAC OOB State............................. Access
Wireless LAN Id.................................. 1
Wireless LAN Network Name (SSID)................. S********
Wireless LAN Profile Name........................ S********
WLAN Profile check for roaming................... Disabled
Hotspot (802.11u)................................ Not Supported
Connected For ................................... 203 secs
BSSID............................................ 04:5f:b9:fd:91:af
Channel.......................................... 108
IP Address....................................... 10.1.51.180
Gateway Address.................................. 10.1.51.2
Netmask.......................................... 255.255.255.0
IPv6 Address..................................... fe80::d:a861:1157:76d4
Last disassociation received from AP............. 04:5f:b9:fd:91:a0
Last disassociation reason....................... Interface disabled
Association Id................................... 111
Authentication Algorithm......................... Open System
Reason Code...................................... 1
Client IPSK-TAG.................................. N/A
Status Code...................................... 0
Session Timeout.................................. 0
Client CCX version............................... No CCX support
QoS Level........................................ Silver
Avg data Rate.................................... 0
Burst data Rate.................................. 0
Avg Real time data Rate.......................... 0
Burst Real Time data Rate........................ 0
Avg Uplink data Rate............................. 0
Burst Uplink data Rate........................... 0
Avg Uplink Real time data Rate................... 0
Burst Uplink Real Time data Rate................. 0
802.1P Priority Tag.............................. disabled
Security Group Tag............................... Unknown(0)
KTS CAC Capability............................... No
Qos Map Capability............................... Yes
WMM Support...................................... Enabled
APSD ACs....................................... BK BE VI VO
Current Rate..................................... 12.0
Supported Rates.................................. 6.0,9.0,12.0,18.0,24.0,36.0,
............................................. 48.0,54.0
Mobility State................................... Local
Mobility Move Count.............................. 0
Security Policy Completed........................ Yes
Policy Manager State............................. RUN
Pre-auth IPv4 ACL Name........................... none
Pre-auth IPv4 ACL Applied Status................. Unavailable
Pre-auth IPv6 ACL Name........................... none
Pre-auth IPv6 ACL Applied Status................. Unavailable
Pre-auth Flex IPv4 ACL Name...................... none
Pre-auth Flex IPv4 ACL Applied Status............ Unavailable
Pre-auth Flex IPv6 ACL Name...................... none
Pre-auth Flex IPv6 ACL Applied Status............ Unavailable
Pre-auth redirect URL............................ none
Audit Session ID................................. 0a01330a0000086f652f7547
AAA Role Type.................................... none
Acct Interim Interval............................ 0
Local Policy Applied............................. none
IPv4 ACL Name.................................... none
AAA FlexConnect ACL Applied Status............... Unavailable
IPv4 ACL Applied Status.......................... Unavailable
IPv6 ACL Name.................................... none
IPv6 ACL Applied Status.......................... Unavailable
Post-auth Flex IPv6 ACL Name..................... none
Post-auth Flex IPv6 ACL Applied Status........... Unavailable
Layer2 ACL Name.................................. none
Layer2 ACL Applied Status........................ Unavailable
URL ACL Name..................................... none
URL ACL Applied Status........................... Unavailable
Client Type...................................... SimpleIP
mDNS Status...................................... Disabled
mDNS Profile Name................................ none
No. of mDNS Services Advertised.................. 0
Policy Type...................................... WPA2
Authentication Key Management.................... FT-PSK
Encryption Cipher................................ CCMP-128 (AES)
Protected Management Frame ...................... Yes
Management Frame Protection...................... No
EAP Type......................................... Unknown
Interface........................................ management
VLAN............................................. 0
Quarantine VLAN.................................. 0
Access VLAN...................................... 0
Local Bridging VLAN.............................. 0
Client Capabilities:
Radio Capability........................... 802.11ax
CF Pollable................................ Not implemented
CF Poll Request............................ Not implemented
Short Preamble............................. Not implemented
PBCC....................................... Not implemented
Channel Agility............................ Not implemented
Listen Interval............................ 10
Fast BSS Transition........................ Implemented
11v BSS Transition......................... Implemented
Non-Operable Channels............................ None
Non-Prefer Channels.............................. None
Client Wifi Direct Capabilities:
WFD capable................................ No
Manged WFD capable......................... No
Cross Connection Capable................... No
Support Concurrent Operation............... No
Fast BSS Transition Details:
Reassociation Timeout...................... 20
Total Preauth APs.......................... 0
Total SuccessFull Roam..................... 0
DNS Server details:
DNS server IP ............................. 0.0.0.0
Assisted Roaming Prediction List details:
Client Dhcp Required: True
Allowed (URL)IP Addresses
AVC Profile Name: ............................... none
OpenDns Profile Name: ........................... none
Fastlane Client: ................................ No
Max DSCP: ....................................... 0
Nas Identifier: ................................. SSC-WLC
Fabric Statistics
Client Statistics:
Number of Bytes Received................... 717905
Number of Bytes Sent....................... 862536
Total Number of Bytes Sent................. 862536
Total Number of Bytes Recv................. 717905
Number of Bytes Sent (last 90s)............ 258662
Number of Bytes Recv (last 90s)............ 219355
Number of Packets Received................. 2167
Number of Packets Sent..................... 2189
Number of Interim-Update Sent.............. 0
Number of EAP Id Request Msg Timeouts...... 0
Number of EAP Id Request Msg Failures...... 0
Number of EAP Request Msg Timeouts......... 0
Number of EAP Request Msg Failures......... 0
Number of EAP Key Msg Timeouts............. 0
Number of EAP Key Msg Failures............. 0
Number of Data Retries..................... 34
Number of RTS Retries...................... 0
Number of Duplicate Received Packets....... 0
Number of Decrypt Failed Packets........... 2
Number of Mic Failured Packets............. 0
Number of Mic Missing Packets.............. 0
Number of RA Packets Dropped............... 0
Number of Policy Errors.................... 0
Radio Signal Strength Indicator............ -45 dBm
Signal to Noise Ratio...................... 53 dB
Client Detected as Inactive................ No
Client RBACL Statistics:
Number of RBACL Allowed Packets............ 0
Number of RBACL Denied Packets............. 0
Client Rate Limiting Statistics:
Number of Data Packets Received............ 0
Number of Data Rx Packets Dropped.......... 0
Number of Data Bytes Received.............. 0
Number of Data Rx Bytes Dropped............ 0
Number of Realtime Packets Received........ 0
Number of Realtime Rx Packets Dropped...... 0
Number of Realtime Bytes Received.......... 0
Number of Realtime Rx Bytes Dropped........ 0
Number of Data Packets Sent................ 0
Number of Data Tx Packets Dropped.......... 0
Number of Data Bytes Sent.................. 0
Number of Data Tx Bytes Dropped............ 0
Number of Realtime Packets Sent............ 0
Number of Realtime Tx Packets Dropped...... 0
Number of Realtime Bytes Sent.............. 0
Number of Realtime Tx Bytes Dropped........ 0
Nearby AP Statistics:
SSC-AP-FF-5(slot 0)
antenna0: 175 secs ago................... -73 dBm
antenna1: 175 secs ago................... -73 dBm
SSC-AP-FF-5(slot 1)
antenna0: 175 secs ago................... -69 dBm
antenna1: 175 secs ago................... -69 dBm
SSC-AP-FF-22(slot 0)
antenna0: 176 secs ago................... -84 dBm
antenna1: 176 secs ago................... -84 dBm
SSC-AP-FF-22(slot 1)
antenna0: 176 secs ago................... -85 dBm
antenna1: 176 secs ago................... -85 dBm
SSC-AP-FF-13(slot 0)
antenna0: 175 secs ago................... -70 dBm
antenna1: 175 secs ago................... -70 dBm
SSC-AP-FF-13(slot 1)
antenna0: 175 secs ago................... -78 dBm
antenna1: 175 secs ago................... -78 dBm
SSC-AP-FF-9(slot 0)
antenna0: 211 secs ago................... -87 dBm
antenna1: 211 secs ago................... -87 dBm
SSC-AP-FF-17(slot 0)
antenna0: 175 secs ago................... -55 dBm
antenna1: 175 secs ago................... -55 dBm
SSC-AP-FF-17(slot 1)
antenna0: 175 secs ago................... -48 dBm
antenna1: 175 secs ago................... -48 dBm
SSC-AP-GF-14(slot 0)
SSC-AP-FF-16(slot 0)
antenna0: 175 secs ago................... -61 dBm
antenna1: 175 secs ago................... -61 dBm
SSC-AP-FF-16(slot 1)
antenna0: 175 secs ago................... -63 dBm
antenna1: 175 secs ago................... -63 dBm
SSC-AP-FF-12(slot 0)
antenna0: 211 secs ago................... -85 dBm
antenna1: 211 secs ago................... -85 dBm
SSC-AP-FF-12(slot 1)
antenna0: 173 secs ago................... -85 dBm
antenna1: 173 secs ago................... -85 dBm
SSC-AP-FF-10(slot 0)
antenna0: 175 secs ago................... -81 dBm
antenna1: 175 secs ago................... -81 dBm
SSC-AP-FF-26(slot 0)
antenna0: 175 secs ago................... -87 dBm
antenna1: 175 secs ago................... -87 dBm
SSC-AP-FF-26(slot 1)
antenna0: 173 secs ago................... -59 dBm
antenna1: 173 secs ago................... -59 dBm
SSC-AP-FF-15(slot 0)
SSC-AP-FF-15(slot 1)
antenna0: 174 secs ago................... -76 dBm
antenna1: 174 secs ago................... -76 dBm
SSC-AP-FF-7(slot 0)
antenna0: 175 secs ago................... -72 dBm
antenna1: 175 secs ago................... -72 dBm
SSC-AP-FF-7(slot 1)
antenna0: 174 secs ago................... -73 dBm
antenna1: 174 secs ago................... -73 dBm
SSC-AP-FF-4(slot 0)
antenna0: 175 secs ago................... -67 dBm
antenna1: 175 secs ago................... -67 dBm
SSC-AP-FF-4(slot 1)
SSC-AP-GF-15(slot 0)
antenna0: 211 secs ago................... -84 dBm
antenna1: 211 secs ago................... -84 dBm
Scan Report:
BSSID:......................................... 04:5f:b9:ff:5a:c2
RSSI:...................................... -77 dBm
ChannelNumber:............................. 6
Aps are connected to CBS350-48P-4G 48-Port Gigabit PoE Managed Switch it's not able to recognise the command.
Wut?
Can you please let me know what should be there instead of that?
