K.e.c.h (help needed)VTP TRUNK DHCP DOT1Q
Brand4470
Vtp mode client
vtp domain
switchport mode trunk
switchport trunk allowed vlan
ip dhcp excluded adress (gateway)
ip dhcp pool vlan 31
default-router 192.168.31.1
network 192.168.31.0 255.255.255.0
interface
no shut
int fa0/0.31
encapsulation dot1q 31
ip add 192.168.31.1 255.255.255.0
no shut
hostname CR01
enable secret 5 $1$mERr$qks.ziZQfY6v/mIalE3YO0
ip dhcp excluded-address 172.17.0.1 172.17.100.0
ip dhcp excluded-address 172.18.0.1 172.18.100.0
ip dhcp excluded-address 172.19.0.1 172.19.100.0
ip dhcp excluded-address 172.31.0.1 172.31.100.0
ip dhcp pool STUDENTEN
network 172.17.0.0 255.255.0.0
default-router 172.17.0.1
ip dhcp pool DOCENTEN
network 172.18.0.0 255.255.0.0
default-router 172.18.0.1
ip dhcp pool TOETSING
network 172.20.0.0 255.255.0.0
default-router 172.20.0.1
ip dhcp pool MANAGEMENT
network 172.31.0.0 255.255.0.0
default-router 172.31.0.1
no ip cef
no ipv6 cef
crypto isakmp policy 10
encr aes
authentication pre-share
group 2
crypto isakmp key PRESTINA address 120.0.0.10
crypto ipsec transform-set VPN-SET esp-3des esp-sha-hmac
crypto map VPN-MAP 10 ipsec-isakmp
set peer 120.0.0.10
set transform-set VPN-SET
match address 110
spanning-tree mode pvst
interface FastEthernet0/0
no ip address
ip nat inside
duplex auto
speed auto
interface FastEthernet0/0.16
encapsulation dot1Q 16
ip address 172.16.0.1 255.255.0.0
ip nat inside
interface FastEthernet0/0.17
encapsulation dot1Q 17
ip address 172.17.0.1 255.255.0.0
ip nat inside
interface FastEthernet0/0.18
encapsulation dot1Q 18
ip address 172.18.0.1 255.255.0.0
ip nat inside
interface FastEthernet0/0.19
encapsulation dot1Q 19
ip address 172.19.0.1 255.255.0.0
ip nat inside
interface FastEthernet0/0.20
encapsulation dot1Q 20
ip address 172.20.0.1 255.255.0.0
ip nat inside
interface FastEthernet0/0.31
encapsulation dot1Q 31
ip address 172.31.0.1 255.255.0.0
ip nat inside
interface FastEthernet0/1
ip address 100.0.0.10 255.0.0.0
ip nat outside
duplex auto
speed auto
crypto map VPN-MAP
interface Vlan1
no ip address
shutdown
ip nat inside source list 101 interface FastEthernet0/1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 100.0.0.1
ip flow-export version 9
access-list 101 permit ip 172.16.0.0 0.15.255.255 any
access-list 101 deny ip 172.16.0.0 0.15.255.255 255.0.0.0 0.255.255.255
access-list 110 permit ip 172.16.0.0 0.15.255.255 10.0.0.0 0.255.255.255
line con 0
password console
login
line aux 0
line vty 0 4
password telnet
login
end
hostname CR02
no ip cef
no ipv6 cef
encr aes
group 2
crypto isakmp key PRESTINA address 100.0.0.10
set peer 100.0.0.10
match address 110
ip address 10.10.0.1 255.255.0.0
ip nat inside
duplex auto
speed auto
ip address 10.16.0.1 255.255.0.0
ip helper-address 10.16.50.1
ip address 10.17.0.1 255.255.0.0
ip address 10.18.0.1 255.255.0.0
ip address 10.19.0.1 255.255.0.0
ip address 10.31.0.1 255.255.0.0
ip address 120.0.0.10 255.0.0.0
ip nat outside
duplex auto
speed auto
crypto map VPN-MAP
interface Vlan1
no ip address
shutdown
ip classless
ip route 10.16.0.0 255.240.0.0 10.10.0.2
ip route 0.0.0.0 0.0.0.0 FastEthernet0/1
access-list 110 permit ip 10.10.0.0 0.0.255.255 172.13.0.0 0.0.255.255
access-list 110 permit ip 10.16.0.0 0.15.255.255 172.31.0.0 0.0.255.255
access-list 110 permit ip 10.31.0.0 0.0.255.255 172.16.0.0 0.15.255.255
access-list 110 permit ip host 10.16.50.1 host 172.16.50.1
access-list 110 permit ip host 10.19.50.1 host 172.19.50.1
access-list 101 deny ip 10.10.0.0 0.0.255.255 172.31.0.0 0.0.255.255
access-list 101 deny ip 10.16.0.0 0.0.255.255 172.31.0.0 0.0.255.255
access-list 101 deny ip 10.31.0.0 0.0.255.255 172.16.0.0 0.15.255.255
access-list 101 deny ip host 10.16.50.1 host 172.16.50.1
access-list 101 deny ip 10.19.0.0 0.0.255.255 any
access-list 101 deny ip 10.10.0.0 0.0.255.255 any
access-list 101 deny ip 10.16.0.0 0.15.255.255 any
line con 0
password console
login
line aux 0
line vty 0 4
password telnet
login
end
=="..." betekent verzin zelf iets==
==*...* morgen==
Belangrijke commandos
show vlan brief
traceroute
ping
ip helper-adress
==CR01==
--Access-lists--
--NAT Access-list--
access-list 101 deny ip 172.16.0.0 0.15.255.255 255.10.0.0 0.255.255.255
ip nat inside source list 101 interface fastethernet0/1 overload
--VPN--
encr aes
group 2
set peer 120.0.0.10
match address 110
crypto map VPN-MAP
==CR02==
--Access lists--
-NAT accesslist-
--Interfaces--
ip nat inside
ip nat inside
interface fa0/0.16
encapsulation dot1q 16
interface fa0/0.17
encapsulation dot1q 17
interface fa0/0.18
encapsulation dot1q 18
interface fa0/0.19
encapsulation dot1q 19
interface fa0/0.31
-VPN-
encr aes
group 2
set peer 100.0.0.10
match address 110
crypto map VPN-MAP
--Routing--
ip route 0.0.0.0 0.0.0.0 Fastethernet0/1
==DS02==
--VTP--
vtp domain PRESTINA-2
vtp mode Server
--VLAN--
vlan 16
name Algemeen
vlan 17
name Studenten
vlan 18
name Docenten
vlan 19
name Toetsing
vlan 20
name Printers
vlan 31
name Beheer
vlan 88
name Black_Hole
vlan 99
name Native
--Interfaces--
interface range fa0/1-6
switchport mode access
switchport access vlan 16
interface range fa0/7-8
switchport access vlan 17
interface range fa0/9-10
switchport access vlan 18
interface range fa0/11-12
switchport access vlan 19
interface range fa0/13-14
switchport access vlan 20
interface range fa0/15-16
switchport access vlan 31
interface range fa0/17-23
switchport access vlan 88
shutdown
interface fa0/24
switchport trunk allowed vlan 17-18,20,31
interface g0/1
no switchport
ip address 10.10.0.2 255.255.0.0
interface g0/2
switchport trunk allowed vlan 19,31
interface vlan16
interface vlan17
interface vlan18
interface vlan19
interface vlan20
ip address 10.20.0.1 255.255.0.0
interface vlan31
--Routing--
ip route 0.0.0.0 0.0.0.0 10.10.0.1
--Access-lists--
"access-list 117 remark 1: Permit dhcp request deny access to vlan 18 & 19 permit further traffic from vlan 17"
access-list 117 permit udp any any eq bootps
access-list 117 deny ip 10.17.0.0 0.0.255.255 10.18.0.0 0.0.255.255
"access-list 117 remark 2: Deny Student verkeer naar Docenten verkeer"
access-list 117 deny ip 10.17.0.0 0.0.255.255 10.1.0.0 0.0.255.255
"access-list 117 remark 3: Permit overig verkeer vanag vlan 17"
access-list 117 permit ip 10.17.0.0 0.0.255.255 any
interface vlan 17
ip access-group 117 in
* access-list 119 *
==AS01==
--VTP--
vtp mode Client
--Default gateway--
ip default-gateway 10.31.0.1
--Interfaces--
int range fa0/1-16
int range fa0/17-18
int range fa0/19-20
interface g0/1
switchport trunk allowed vlan 16-18
int vlan31
ip address 10.31.10.1 255.255.0.0
==AS-T==
--Default-gateway--
--Interfaces--
int range fa0/1-24
interface g0/2
interface vlan 31
ip address 10.31.10.11 255.255.0.0
no sh
Gerelateerde afbeelding
TO TO TO TO
VPN-conf
encr = [aes]
crypto isakmp key [prestina] address [120.0.0 .10]
crypto ipsec transform-set [VPN-set] esp-3des esp-sha-hmac
crypto map [VPN-MAP] 10 ipsec-isakmp
set peer [120.0.0.10]
set transform-set [VPN-SET]
match address [110]
Interface [fast ethernet]
Crypto map [VPN MAP]
access-list 110 [permit ip 172.16.0.0 0.15.255.255 10.0.0.0.0.255.255.255]
access-list 101 [deny ip 172.16.0.0 0.15.255.255 10.0.0.0.255.255.255]
[access-list 101 permit ip 172.16.0.0.0 0.15.255.255 any]
ip nat inside source list 101 interface fastethernet 0/1 overload]
[2] x switch l2
[3] x switch l3
[1] x router
[4] x server
server dn = 10.18.50.1/16
t server = 10.19.50.1/16
Vlan [18] 10.18.0.1 | 10.18.100.1 | [30]
Vlan [19] 10.19.0.1 | 10.19.100.1 | [30]
Vlan 31 10.31.0.1 [30]
brand, type Cisco [2811]
interfaces:
fast ethernet0/0 ip 120.0.0.1/16
ip nat [inside]
fastethernet0/1 IP 120.0.0.10/8
ip nat [inside]
VPN-conf
encr [aes]
crypto isakmp key [prestina] address [100.0.0.10]
crypto ipsec transform-set [VPN-SET] esp-3des esp-sha-hmac
set peer [100.0.0.10]
set transform-set [VPN-set]
match address [110]
interface [FastEthernet0/1]
crypto map [vpn-map]
VPN-access-list:
access-list 110 [permit ip 10.10.0.0 0.0.255.255 172.13.0.0 0.0.255.255]
access-list 110 permit ip 10.16.0.0 0.15.255.255 172.31.0.0 0.0.255.255]
access-list 110 permit ip 10.31.0.0.0.0.255.255 172.16.0.0 0.15.255.255]
NAT-access list:
access-list 101 [deny ip 10.10.0.0 0.0.255.255 172.31.0.0 0.0.255.255]
access-list 101 [deny ip 10.16.0.0 0.15.255.255 172.31.0.0 0.0.255.255]
access-list 101 [deny ip 10.31.0.0 0.0.255.255 172.16.0.0 0.15.255.255]
nat-access-list [source list 101 interface fastethernet0/1 overload]
routing
Default route instellen: ip route 10.16.0.0 255.240.0.0 10.10.0.2
Routes(s) naar VLAN's inste!!en : 0.0.0.0 0.0.0.0 FastEthernet0/1
distributieswitch
vtp mode: server
interface
mode & vlans
[F0/1-6] mode access vlan 16
[F0/7-8] mode access Vlan 17
[F0/9-10] mode access vlan 18
[F0/11-12] mode access Vlan 19
[F0/13-14] mode access vlan 20
[F0/15-16] mode access vlan 31
[F0/17-23: mode access vlan 88, shutdown
[F0/24: Mode access trunk, allowed vlan(s) 17-18,20,31
[G0/1: Mode access ip 10.10.0.2/16
[G0/2: Mode access trunk, allowed vlans 19,31
lnterface(s) Vlan16: Mode access IP:10.16.0.1/16
lnterface(s) Vlan17: Mode access IP:10.17.0.1/16
intertfaces vlan 18: mode access ip 10.18.0.1/16
interfaces vlan 19: mode access ip 10.19.0.1/16
interfaces vlan 20: mode access ip 10.20.0.1/16
interfaces vlan 31: mode access ip 10.31.0.1/16
interface(s) interface 17 ip helper-address: IP:10.16.50.1
interface(s) interface 18 ip helper-address: IP:10.16.50.1
interface(s) interface 13 ip helper-address: IP:10.16.50.1
Ip-addressen
Interface G0/1: IP:10.10.0.2 /16
interface vlan 16: IP: 10.16.0.1/16
interface vlan 17: IP: 10.17.0.1/16
interface vlan 18: IP: 10.18.0.1/16
interface vlan 31: IP: 10.31.0.1/16
DHCP REQUESTS to DHCP SERVER
routing
[ip routing]
ip route 0.0.0.0 0.0.0.0. 10.10.0.1
access-lists 117
access-list 117 [permit udp any any eq bootps]
access-list 117 [deny ip 10.17.0.0 0.0.255.255 10.18.0.0 0.0.255.255]
access-list 117 [deny.ip 10.17.0.0 0.0.255.255 10.1.0.0 0.0.255.255]
access-list 117 remark 3: Permit overig verkeer vanaf vlan 17
access-list 117 [permit ip 10.17.0.0 0.0.255.255 any]
interface [VLAN 17]
IP-access-group 117 in
access-list 119
[Geef detoets-server-alleen toeg.fil]g tot:
~ De toets-server in Bbroek
Ó Het beheer-VLAN in Bennebroe~
o Het beheer-VLAN in A
• Maak van toepassing op de juiste interface
access switch leslokalen
Merk, type:Cisco 2960
Hostname:AS01
VTP mode:[client]
default gateway: 10.31.0.1
interfaces trunk, allowed vlans [19,31]
vlan 31 IP: [10.31.10.1/16]
ap sn
ssid prestina studenten
authen wpa2
preshared key student-prestina
AP DN
ssid prestina docenten
authen wpa 2
preshared key docentprestina99873
printers
01 ptr01 10.20.20.1] [10.20.0.1]
02 ptr02 10.20.20.2) 10.20.0.1)
toetsing ptr-t [10.19.20.1) [10.19.0.1]
interne poorten
80 http
443 https
500 dns
externe poorten
500 isakmp
50 esp
80 http
totaal: 10.556,78
18 Replies 18
Mike Snoei
Extra’s
  • Config# do write memonry (do wr m)
  • R1 copy running-configuration startup-configuration
DHCP configuratie
R1           Interface fa0/0
                Ip address 192.168.10.1 255.255.255.0
                No shutdown
                Ip dhcp pool IPPOOL
                Network 192.168.10.0 255.255.255.0
                Default 192.168.10.1
R2           Int fa0/0
                Ip address ….
                Ip helper-address ip van dhcp server
                No shutdown
                Alle connecties van router
S1           Vlan 10
                Name VLANName
                Exit
                Int range fa0/1-8
                Switchport mode acces
                Switchport access vlan 10
                (herhaal voor alle vlans)
                (native vlan niet vergeten)
VTP
S1           Vtp domain VTPDomain
               Vtp mode Server of Clients
               Switchport mode trunk
               Switchport trunk allowed vlan 1-99lll
GRE-Tunnel
Int tunnel0
Tunnel source
Tunnel destination
Tunnel mode gre ip
Ip route door tunnel
Mike Snoei
GRE-tunnel:
- int tunnel 1 (beide kanten)
- tunnel source (poort IP)
-tunnel destination(tegengestelde IP)
Routes veranderen
ipsec:
- license ?
- acces-list (beide kanten)
- crypto isakmp policy 10 x
encryption aes 256
hash md5
group 5
-crypto isakmp key (...) address (ip tegenover)
- crypto ipsec transform-set (...) esp-aes esp-sha-hmac
-crypto map (...) (nummer, policy) ipsec-isakmp
set peer (tegenover)
set transform-set (...)
match address (acces-list no, erbij hoort)
- int se0/0/0
crypto map (..)
sh crypto ipsec sa
SSH op switch:
-hostname
- enable password (xx)
-line vty 0 4
password
login
-ip domain name
- crypto key gen rsa 2048
- line vty 0 4
- transport input ssh
- password
- int vlan (xx) geen laatste ip!
- ip add
test:
verbind device, dezelfde vlan
Ssh -l admin (ip van int vlan)
Post-sec:
-interface gi/fa
-switchpoort mode access
-switchpoort port-sec
-switch[poort port-sec violation prot/restr/shutdown
-switchpoort port-sec max 1
-switchpoort port-sec mac-address (...)/sticky
NAT:
-ip nat inside/outside
-ip nat inside sub interfaces
-ip nat pool
-ip nat inside source
-ip acl
-dhcp pool dns geven
-ip route (server ip)
Show com NAT trans:
- show ip nat trans
Main root STP:
- spanning-tree mode rapid
- spanning-tree vlan 1 root primary
Second:
- Spanning-tree mode rapid-pvst
- spanning-tree vlan 1 root secondary
- Show spanning tree
- Lowest Mac-adres is autmatic root bridge
Laag 3 DHCP inter vlan:
- vlan aanmaken
- int vlan
- dhcp pools
- vtp domain etc.
-no switchport
switchport nonegotiate
VIA SERVER IP:
Server: IP geven, pools aanmaken, DHCP ''On''
Multilayer: vtp, vlan, int vlan, trunk. access vlan naar de server
switch: vtp. access vlan
R1 copy tftp: flash:
IP van server
source FILENAME in de server
boot system flash FILENAME
copy run start
reload
Backup
R1 copy flash: tftp:
IP van server
Testen
R1 show flash:
show version
