If your Cloud Collaboration question is not answered quickly, please email devsupport@webex.com for additional help
457
Beginner
Jabber Web SDK: Set local Audio/Video and get remote Audio/Video
I want to add the ability to videoconference to an existing application.
For the integration with the application I need the following capabilities:
- Set the audio samples and video frames that will be sent to the remote caller.
- Access audio samples and remote video frames.
Is this possible with Jabber Web SDK?
Thanks.
1 REPLY 1
Highlighted
Re: Jabber Web SDK: Set local Audio/Video and get remote Audio/Video
The Jabber SDK is designed to abstract all the audio/video handling - there is no programmatic access to the audio/video streams by a SDK application.
You might be able to accomplish what you want by implementing a virtual 'CTI Port' device, which does specifically allow/require an application to handle the incoming/outgoing media.  CTI Ports are instantiated/controlled using the TAPI or JTAPI CTI interfaces:
https://developer.cisco.com/site/jtapi/
https://developer.cisco.com/site/tapi/
