movaswan
Introduction
The CloudCenter platform supports integration to various Load Balancers. This document provides information on integration with A10 Lightning ADC and Harmony Controller by creating an external service in CloudCenter.
A10 Lightning ADC is cloud-native and is a software that can be installed on a Linux machine. It is a state-less data-plane device. Configuration of Lightning ADC is fully managed by Harmony Controller that is available as SaaS.
Lightning ADC is purpose-built for containers & micro-services and includes
  • Advanced traffic management: elastic load balancing, content based switching, AWS zone-based affinity, automated Blue/Green deployments
  • Performance optimization: compression, caching, connection multiplexing
  • Application security: WAF for protecting OWASP top 10 vulnerabilities like sql- injection, XSS, CSRF, protection against bad BOTs, malware, application DDoS attacks
Harmony Controller (SaaS) provides
  • Simplified operations with centralized policy management across AWS regions, clouds and datacenters
  • Visibility into distributed environment with per-application metrics, analytics & insights
  • Automation via APIs & integration's with devops tools
Prerequisites
CloudCenter
  • CloudCenter 4.6.x and above
A10 Networks
  • A tenant account on SaaS Harmony Controller
  • Internet connectivity for calling Harmony controller APIs and Installing Lightning ADC software
Service Description
Configuring A10 Lightning ADC consists of various steps
  • Create a Lightning ADC Cluster object in the Harmony Controller and retrieve the cluster ID
  • This cluster ID will be used to install the Lightning ADC instances. All instances with the same cluster ID will become part of the cluster on connection to the Harmony Controller
  • Launch Lightning ADC instances
  • Create a minimal application configuration with default policies in the Harmony Controller and attach the Lightning ADC cluster.
These steps will be divided into 3 services:
  1. Lightning ADC Cluster Creation (External Service)
  2. A10 Lightning ADC (Virtual Machine with agent)
  3. Harmony App Creation (External Service)
__________________________________________________
Harmony Cluster Creation
To add this service login to CloudCenter as an administrator and click on Admin->Services->Add Service. Use the information listed below to create the service.
Service Type: External Service
Name: Harmony Cluster Creation
Service ID: a10clustercreation
Description: Create a Lightning ADC cluster under the tenant for which credentials. Multiple Lightning ADCs can be launched with one cluster ID. All these Lightning ADCs will form a logical cluster and handle the traffic in active-active configuration.
Category: Custom Service
External Lifecycle Actions:
External Action Bundle: <location of a10clustercreation.zip>
Start:
     Script from Bundle: controllerservice start
Service Parameters
Parameter Namea10_api_server
Display NameA10 API Server
Typestring
Default Valuehttps://api.a10networks.com/api/v2
User Options
Parameter Namea10_user
Display NameA10 User
Typestring
Default Value
User Options
Parameter Namea10_user_passwd
Display NameA10 User Password
Typepassword
Default Value
User Options
Deployment Parameters
Parameter Nameprovider
Display NameProvider
Typestring
Default Value
User OptionsVisible, Editable
Parameter Nametenant
Display NameTenant
Typestring
Default Value
Parameter Namecluster_name
Display NameCluster Name
Typestring
Default Value
A10 Lightning ADC
Note: You can attach a scaling policy to this tier.
Service Type:Virtual Machine
Name: A10 Lightning ADC
Service ID: a10lightningADC
Description: Install Lightning ADC software on the virtual machine.The launched Lightning ADC will automatically attach itself to the cluster whose cluster ID is provided.
Supported Images: CentOS 7.x
Agent Lifecycle Actions:
Start:
     URL: <location of adcclusterservice.sh>
Service Parameters
Typestring
User Options
Parameter NameminClusterSize
Display NameMinimum Number of Nodes
Typenumber
Default Value 1
Parameter NamemaxClusterSize
Display NameMaximum Cluster Size
Typenumber
Default Value1
___________________________________________________
Name: Harmony App Creation
Service ID: a10appcreation
Description:Create an application and associated configuration hierarchy (with defaults) in Harmony Controller. It also attaches the Lightning ADC cluster to the application and makes it ready to use.
Category: Load Balancer
External Action Bundle: <location of a10appcreation.zip>
Update:
     Script from Bundle: controllerservice update
Start:
Stop:
     Script from Bundle: controllerservice stop
Service Parameters
Typestring
User Options
Typestring
Default Value
User Options
Typepassword
Default Value
User Options
Typestring
Default Value
Display NameTenant
Typestring
Default Value
Typestring
Default Value
Parameter Nameapp_name
Display NameApplication Name
Typestring
Default Value
Parameter Namedomain_name
Display NameDomain Name
Typestring
Default Value
Parameter Nameservice_name
Display NameService Name
Typestring
Default Value
Sample Application
Here is an sample application profile that uses these services:
Downloads
