Orf Gelbrich
Task Name Execute workflow in UCSD
Description
  1. Example on how to execute a workflow In UCSD from AO
Prerequisites
  1. Tested on AO 1.0
Category Workflow
Components API
User Inputs
  1.
  2. Import workflow (details are coming)
  3.
The workflow:
The target definition is as follows:
HTTP Endpoint definitionHTTP Endpoint definitionFurther target setupFurther target setup
Webservice HTTP request:
WEB services detailsWEB services detailsWEB services detailsWEB services detailsWEB services detailsWEB services details
Output on successful workflow execution:
 Git download
https://github.com/ogelbric/CCCAOWorkflows/tree/master/definition_workflow_1CiW5ecaipHqxIVYGxLqBBti5kl
anusha akula
The given git repository is inaccessible, can you post us the active git repo link
