movaswan
Overview
The CloudCenter platform allows you to define your own parameters or use the CloudCenter-supported parameters as identified in Parameters and Macros > Parameter Type. The webservice option is listed in the Parameter Type dropdown. If you configure this option, you must provide the Protocol (HTTP or HTTPS), Web Service URL, and the credentials (Username and Password) for the webservice. To do this, you can optionally launch an isolated Arcus server and configure the webservice to point to the Arcus server. Arcus is an API broker and translator.
While the CloudCenter platform provides the Arcus integration, it is up to the customer using this feature to address the following dependencies:
  • Send requests to the device's API URL
  • Call the correct device-specific webservice method
  • Convert the webservice response to the format expected by CloudCenter
For details on how to use Arcus with CloudCenter please refer to the CloudCenter Documentation
This document list various Device types and templates that you can import into Arcus and use with Cloud Center.
Device Types and Templates
The following content is listed by the devices. Please refer to this sample document on how to import these device types and templates into Arcus.
Device: AVI Networks
Device Type: AVI Controller
Templates:
Template Name
Description
AVI-GetHealthMonitorGet the list of health monitors from AVI Controller
AVI-GetApplicationProfileGet list of application profiles from AVI Controller
AVI-GetPersistenceProfileGet list of persistence profiles from AVI Controller
Device: F5 Networks
Device Type: F5
Templates:
Template Name
Description
F5-GetNodeByNameGet the list Nodes by Name
F5-GetNodeByFullPathGet list of Nodes by Node's full Path
Device Type: F5 iWorkflow
Templates:
Template Name
Description
F5W-GetCloudConnectorsGet the list of Cloud Connectors
F5W-GetTenantNamesGet list of Tenant Names
F5W-GetIappTemplateNamesGet list of (iApp) Templates
Device: Cisco ACI
Device Type: ACI
Templates:
Template Name
Description
ACI-GetVlanPoolNamesGet list of VLAN Pool names from the ACI Fabric
ACI-GetLeaPolicyGroupNamesGet list of Leaf Policy Group names from the ACI Fabric
ACI-GetTenantNamesGet list of Tenant from the ACI Fabric
Device: EMC ViPR
Device Type: EMC ViPR
Templates:
Template Name
Description
VIPR-GetHostsGet the list of hosts that ViPR has in inventory
VIPR-GetHostIpInterfacesGet a list of IP interfaces based off of the host_id specified
VIPR-GetVirtualArraysGet list of Virtual Arrays that ViPR has in inventory
VIPR-GetVcenterListGet a list of vCenters that ViPR has in inventory
ViPR-GetVirtualBlockPoolsGet a list of the Virtual Block Pools
Device: Cisco UCS Central
Device Type: UCS Central
Templates:
Template Name
Description
UCSC-GetPermittedVlansGet a list of Permitted VLANs from UCS Central
UCSC-GetMacPoolsGet a list of MAC Pools from UCS Central
UCSC-GetServiceProfilesGet a list of Service Profiles from UCS Central
UCSC-GetOrgsGet the list of Orgs from UCS Central
Device: VMware vCenter
Device Type: vSphere
Templates:
Template Name
Description
VC-GetVMListGet a list of Virtual Machines
VC-GetVMListNoBlanksGet a list of Virtual Machines and remove blank entries
Device: Cisco HyperFlex
Device Type: HyperFlex Controller
Templates:
Template Name
Description
HX-GetDatastoreCommonNameGet a list of HyperFlex Datastores
Device: NetApp
Device Type: NetApp SolidFire
Templates:
Template Name
Description
SF-GetActiveVolumesGet the list of active Volumes from the SolidFire Controller
Device: CloudCenter
Device Type: CloudCenter
Templates:
Template Name
Description
C3-GetJobsListGet the list of Jobs from CloudCenter Manager
C3-GetUsersListGet the list of Users from CloudCenter Manager
