The CloudCenter platform supports integration to various load balancers. This document provides information on integration with Avi Networks to handle creating virtual services, pools, pool servers, and adding or removing servers from pools during a scaling operation.
The Avi Vantage Platform delivers automated application services including load balancing, application analytics, predictive autoscaling, and security for on-premises or public cloud applications. The platform is built on software-defined principles, runs on commodity x86 servers, VMs, or containers, and matches the automation and self-service goals of modern enterprises.
The Packer Service bundle consists of the following files:
The parameter name is key here and should match the parameter name in the UI
To add this service login to CloudCenter as an administrator and click on Admin->Services->Add Service. Use the information listed below to create the service.
Service Type: External Service
Service ID: avinetworks
Description: The Avi Vantage Platform delivers automated application services including load balancing, application analytics, predictive autoscaling, and security for on-premises or public cloud applications.
Category: Load Balancer
External Lifecycle Actions:
External Action Bundle: <location of avinetworks.zip>
Update:
Script from Bundle: service update
Start:
Script from Bundle: service start
Stop:
Script from Bundle: service stop
Service Parameters
Parameter Name | aviControllerIp |
Display Name | Avi Controller IP |
Type | string |
Default Value | |
User Options |
Parameter Name | aviControllerUserName |
Display Name | Avi Controller User Name |
Type | string |
Default Value | admin |
User Options |
Parameter Name | aviPassword |
Display Name | Avi Controller Password |
Type | password |
Default Value | |
User Options |
Deployment Parameters
Parameter Name | aviTenantName |
Display Name | Avi Controller Tenant Name |
Type | string |
Default Value | |
User Options | Visible, Editable |
Parameter Name | vipName |
Display Name | Virtual Service Name |
Type | string |
Default Value | |
Parameter Name | vipIp |
Display Name | Virtual Service IP |
Type | string |
Default Value | |
Parameter Name | vipPort |
Display Name | Virtual Service Port |
Type | string |
Default Value | 80 |
Parameter Name | sslEnable |
Display Name | Enable SSL |
Type | list |
List Values | Yes,No |
Default Value | No |
Parameter Name | sslCert |
Display Name | SSL Certificate |
Type | path |
Default Value | |
Parameter Name | sslKey |
Display Name | SSL Key |
Type | path |
Default Value | |
Parameter Name | appProfile |
Display Name | Avi Application Profile |
Type | list |
List Values | System-DNS,System-HTTP,System-L4-Application,System-SSL-Application,System-Secure-HTTP |
Default Value | System-HTTP |
Parameter Name | persistence |
Display Name | Persistence |
Type | list |
List Values | System-Persistence-App-Cookie,System-Persistence-Client-IP,System-Persistence-Custom-Http-Header,System-Persistence-Http-Cookie,System-Persistence-TLD |
Default Value | System-Persistence-Http-Cookie |
Parameter Name | lbMethod |
Display Name | Load Balancing Method |
Type | list |
List Values | Round Robin,Least Load,Fewest Servers, Consistent Hash,Fastest Response,Core Affinity,Least Connections |
Default Value | Least Connections |
Parameter Name | listenPort |
Display Name | Pool Server Port |
Type | string |
Parameter Name | poolMembers |
Display Name | Pool Servers |
Type | string |
Default Value | |
User Options |
Parameter Name | poolMonitor |
DisplayName | Health Monitor |
Type | list |
List Values | System-DNS,System-HTTP,System-HTTPS,System-Ping,System-TCP,System-UDP |
Default Value | System-TCP |
