Changing the CloudCenter Orchestrator to direct clients to an internal repo
591
Summary:
Certain deployments may restrict application nodes from accessing the internet when they are provisioned by CloudCenter (CC), thereby limiting their access to required files hosted by CC's public repositories. In such cases, it is necessary for an internal repo server(s) to be deployed to mimic the public repos. Internal repositories require routine maintenance, specifically to keep their file versions parallel to those of the  CC appliances.
Logging on to the CloudCenter Orchestrator (CCO):
The following are sample methods of authenticating to a CCO image provided by Cisco
IaaS
FormatUsernamePassword
vCenterOVArootwelcome2cliqr
Amazon AWSAMIcentosN/A  *key pair required
OpenStackQCOWrootN/A  *key pair required
MetaCloudRAW (converted from QCOW)rootwelcome2cliqr or key pair
Editing the properties files:
  • Step 1: On the CCO, navigate to /usr/local/tomcat/webapps/ROOT/WEB-INF
    • command
      cd /usr/local/tomcat/webapps/ROOT/WEB-INF
  • Step 2: Create a backup of the gateway.properties file
    • commandcp gateway.properties{,.bak}
  • Step 3: Edit the gateway.properties file
    • command
      vi gateway.properties
gateway.properties
## Encryption parameters
salt=cliqr technology inc. secret salt
bootstrapData=osmosix
useStrongEncryption=true
## URL to bootstrap script
agent.bundle.url=http://192.168.200.130/bundle/bootstrap-cliqr-worker.sh
agent.bundle.url.windows=http://192.168.200.130/bundle/bootstrap-cliqr-worker.ps1
dfs.bundle.url=http://192.168.200.130/bundle/bootstrap-cliqr-dfs.sh
hazelcast.mapstore.enabled=true
#separate ldap and activemq from gateway
gateway.separate.enabled=false
ldap.server.ip=localhost
jms.server.ip=localhost
hazelcast.tcpip.enabled=true
hazelcastIPList=127.0.0.1
bootstrap.js.url=http://192.168.200.130/bundle/bootstrap.json
bootstrap.ssh.url=http://192.168.200.130/bundle/bootstrap-cliqr-ssh.sh
bootstrap.py.url=http://192.168.200.130/bundle/cliqr-bootstrap.py
bootstrap.win.url=http://192.168.200.130/bundle/bootstrap-cliqr-init.ps1
bootstrap.linux.url=http://192.168.200.130/bundle/bootstrap-cliqr-init.sh
bootstrap.ps.url=http://192.168.200.130/bundle/cliqr-bootstrap.ps1
#Time gateway waits before performming bootstrapping
bootstrap.waittime=15
#path to repo containing all system service bundles
system.service.bundle.path=http://192.168.200.130/bundle/services
#path to repo containing all external system service bundles
system.external.service.bundle.path=http://sp-poc.s3.amazonaws.com/bundle/services/external
#optional path to the repo server containing all the .deb and .rpm packages
custom.repository.url=http://repo.cliqrtech.com
# Agent Upgrade metada
agent.upgrade.linux.url=http://192.168.200.130/bundle/upgrade-linux.json
agent.upgrade.win.url=http://192.168.200.130/bundle/upgrade-win.json
node.metadata.url=http://192.168.200.130/bundle/cloud-node-metadata.war
maximum.bootstrap.wait.time=3600
node.heartbeat.time=180000
  • Step 6: On the internal repo server, navigate to the bundle directory (the location of this directory is dependent upon the user's discretion at the time of the repo server's deployment). This example assumes that the files pertaining to the Package repo and the Bundle repo are hosted on the same server, and that package files are stored in the /repo directory and bundle files are stored in the /repo/bundle directory
    • command
      cd /repo/bundle
Content for Community-Ad
