Highlighted
Enthusiast
For me it had to do with the
For me it had to do with the port being used for the SIP trunk between Expressway-C and CUCM. We were overlapping the default 5060 which it didn't like. It wasn't clear in the documentation. But in my case Phone Services never connected through Expressway but worked internally.
It working sometimes but not others will probably require you to look at logs to find out why it's not always connecting.
Highlighted
Yes Jakub,I have sorted out
Yes Jakub,
I have sorted out it by changing the port from 5060 to 5065 and it worked and now checking the ports 2776 and 2777 on firewall as it seems they are blocked between expressway-C and E.
Highlighted
Enthusiast
Glad it worked out :)
Hopefully this can help someone else out in the future. I remember spending a lot of time on this problem. IM was working but phone services would not connect.
Highlighted
Hi Gents,As i have shared the
Hi Gents,
As i have shared the info every thing is workign fine including voice which was not working due to ports 2776 and 2777 was blocked on firewall. Now i am facgin another challenge.
I have two IM servers in HA mode and now all the users from IM pub can login while all the users which are associated with IM subs are getting error on Jabber that can not locate to the server. When i have checked their confign on Jabber Iphone i have found the automatic configuration is routing to only IM Pub server and not checking both servers.
Any help would be great.
Highlighted
Hi Sheraz.Did you configure ,
Hi Sheraz.
Did you configure , on user service profile both IM&P servers?
Are all users able to login while inside the corporate LAN?
Please let me know
Carlo
Please rate all helpful posts "The more you help the more you learn"
Highlighted
Hi Carlo,Where can i check
Hi Carlo,
Where can i check this on user service profile settings. Yes internally all users are able to login regardless of their users registration server.
Sheeraz
Highlighted
Hi Sheraz.You can check it on
Hi Sheraz.
You can check it on
"User Management" -->> "User Settings" --->> "UC Service" to check if both IM&P servers were defined.
 "User Management" -->> "User Settings" --->> "Service Profile" to see if a Service Profile has been defined and both server are there as Primary and Secondary.
Once all above is fine, check that all interested users have a Service Profile defined on "User Management" -->> "End User"
Select one user and check "UC Service Profile" value.
Carlo
Highlighted
Hi Carlo,Okay i have checked
Hi Carlo,
Okay i have checked the both IM servers are added in also in UC service profile IM subscriber is also added as secondary server but the status is same. When i make both IM servers UP all the users which are associated to IM server 2 doesn't get login.
Br,
Sheeraz
Highlighted
Hi Jakub.I upgraded to 8.5.2
Hi Jakub.
I upgraded to 8.5.2 from 8.5.1 with no issue, but I found this issue after an upgrade from 8.5.2 to 8.5.3.
I think that 8.5.1 is the most stable release till now.
Cheers
Carlo
Highlighted
Enthusiast
I tried 8.5.3 this morning
I tried 8.5.3 this morning and reverted back to 8.5.1
I was unable to reach my CUCM from Expressway C anymore. Reverting fixed the issue again. I think I might just stick with 8.5.1 since it just works
Highlighted
Hi all,i start a new
Hi all,
i start a new installation for a my custoemer with cucm 10.5.2 and expressway 8.5.2, upgraded in a second step to 8.5.3
I have complete the MRA configuration without any warnings, but form intenternet  the Jabber can't login.
the jabber client  says "wrong user or pwd".
from the Exp-c logs i can see:
2015-06-19T13:42:05+02:00 expc UTCTime="2015-06-19 11:42:05,761" Module="developer.edgeconfigprovisioning.uds" Level="INFO" CodeLocation="udsmanager(593)" Service="UDSManager" Detail="Found user cluster" Identity="('username', 'carlo.michelotti')" Cluster="CUCM.company.com"
2015-06-19T13:42:05+02:00 expc edgeconfigprovisioning: Level="WARNING" Service="UDSManager" Detail="User cluster not found" Identity="('username', 'carlo.michelotti')" Cluster="CUCM.company.com" Reason="UC node cucm.company.com not found" UTCTime="2015-06-19 11:42:05,761"
2015-06-19T13:42:05+02:00 expc edgeconfigprovisioning: Level="WARNING" Service="ECS" Detail="Request failed" User="('username', 'carlo.michelotti')" Reason="Home CUCM not available - Tried all available UDS" UTCTime="2015-06-19 11:42:05,761"
2015-06-19T13:42:05+02:00 expc edgeconfigprovisioning UTCTime="2015-06-19 11:42:05,761" Module="network.http.edgeconfigprovisioning" Level="DEBUG" Action="Send" Local-ip="127.0.0.1" Local-port="22110" Src-ip="127.0.0.1" Src-port="32151"
HTTPMSG:
|HTTP/1.1 401 Unauthorized
 WWW-Authenticate: Basic realm="Cisco-Edge"
 Server: CE_C ECS
not sure that I'm in the same case of other user there, but I'll try to downgrade to 8.5.1
I will update you..
C.
Highlighted
Beginner
I'm having this exact problem
I'm having this exact problem after upgrade from 8.5.1 to 8.5.3. The users are getting the invalid username or password.
I will try to downgrade to version 8.5.1.
2015-06-23T18:07:35-04:00edgeconfigprovisioning: Level="WARNING" Service="ECS" Detail="Request failed" User="" Reason="Home CUCM not available - Tried all available UDS" UTCTime="2015-06-23 22:07:35,870"
2015-06-23T18:07:35-04:00edgeconfigprovisioning: Level="WARNING" Service="UDSManager" Detail="User cluster not found" Identity="" Cluster="" Reason="UC node  not found" UTCTime="2015-06-23 22:07:35,870"
Highlighted
Beginner
The issue is still remains at
The issue is still remains at 8.5.3 if you are using split/multiple domains, please see the following the
links from bug tool search. From my experience 8.5.1 version is more stable for the MRA deployment.
https://tools.cisco.com/bugsearch/bug/CSCuu31716
https://tools.cisco.com/bugsearch/bug/CSCuu64394
Highlighted
Enthusiast
What version of CUCM are you
What version of CUCM are you running? 10.5(1) is not compatible with X8.5.3. If you upgrade CUCM to 10.5(2) everything works as intended.
Highlighted
Great suggestion Jakub+5;)
+5
Cheers
Carlo
Content for Community-Ad
Future of Work Virtual Summit Day 5
Cisco COVID-19 Survey
