07-17-2019 10:44 AM
Is it possible to have the Contacts field in Jabber be auto-populated with members from a specific AD group? For instance if users are added and removed from say the "Staff" AD group, will it add/remove those users automatically when syncing from AD into the Jabber "Contacts" list?
I can't seem to find an answer for this. I know you can manually upload a contacts list, but that's kinda a pain when you could potentially sync it from a Group that is maintained automatically.
Thanks!
07-17-2019 11:25 AM
Read here:
07-17-2019 11:27 AM
07-18-2019 12:01 PM
AFAIK that's not possible, you would need to create a small doc of how to add the group(s) they should have and explain they will not be able to add/remove contacts from them as they're centrally managed.
