1064
Highlighted
Beginner
Business Edition 6k upcoming Rls
After Prime Collaboration gone EOS, how many applications are available for C220M?
Expressway-c and Expressway-E are included or are available as a separate .ova format?
Any consolidated implementation and configurational document for BE6k along with ISR 4XXX routers and Expressway -C and expressway-E?
How can we design BE6K + ISR 4xxx + Expressway-c & E within a same building but different data centers as fully HA format?any relevant CVD?
33 REPLIES 33
Highlighted
Nithin,
please help me to read out this option in BOQ.
"Cisco Touch10 controller for collaboration end points"
"Cisco Meeting Server"
further is webexMeeting required for MX800 and jabber or not compulsory in presence of BE6k+ Expressways? Or webex meeting is a separate individual application for Video con...
Highlighted
Cisco meeting server is the conference resource
you can learn more from below link.
https://www.cisco.com/c/en/us/products/conferencing/meeting-server/index.html#~features
Cisco Meeting Server brings premises-based video, audio, and web communication together to meet the collaboration needs of the modern workplace. It works with third-party devices, and provides an enjoyable and intuitive user experience. It also scales easily, and can be purchased using our all-in-one, user-based multiparty licensing offer.
Regarding MX800 registration supported call control. it can be on Prem call control or Webex Cloud.
The systems now support cloud registration to Cisco Webex for even faster and more cost effective deployment2.
Go through below data sheet.
https://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/telepresence-mx-series/datasheet-c78-731263.html
==Please rate all useful posts and mark as answer if it solves your issue==
Highlighted
Hi Nithin,
Hope you are fine.
what does it means in my BOQ list along with BE6K + MX800.
" choose of VCS or for CUCM version 11.x TP-Room License."
Highlighted
choose of VCS or for CUCM version 11.x TP-Room License means,  you can register MX 800(I believe u are using MX as VC end Point) on CUCM and TP room license will be utilized by CUCM or on expressway C server using LIC-EXP-ROOM license.
when you purchase TP-Room license you also get LIC-EXP-ROOM which is free. If you need to register MX-800 on VCS you can use LIC-EXP-ROOM license on expressway C.
Highlighted
Nithin,
what is the role of " RMS licensing included with PMP & SMP"
Highlighted
RMS:- Rich Media Session license.
Rich Media Sessions
If your system has a rich media session key installed and thus supports business-to-business calls, and interworked or gatewayed calls to third-party solutions and so on.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/expressway/config_guide/X12-6/exwy_b_mra-expressway-deployment-guide/exwy_b_mra-expressway-deployment-guide_chapter_01101.html
https://www.cisco.com/c/en/us/support/docs/unified-communications/expressway/214621-understand-expressway-and-vcs-license-in.html
Highlighted
Nithin,
In new implementation mode, using BE6k
are we need to create SIP trunk and Sip profile in between each component?
i.e CUCM+ IM&P+ Unity Connection + Unified Attendant Console advance + Expressway C & E + Prime Collaboration
Second, License will be deployed in BE6K Pub and as well as BE6K Sub both or only BE6k Pub.
in case of Primary (Pub) failure how will be licenses will entertained?
Highlighted
Sip Trunk depends on your deployment. if you go through the the Design Guide shared you can plan it.
if the version which you are using is 12.X, its smart licensing. the license will be deposited in smart account.
version 11.X its PLM. install the license in PLM and add the unity and CUCM publishers instances.
you can learn more about Smart licensing from below link.
https://www.cisco.com/c/en/us/products/software/smart-accounts.html?socialshare=video_b1
Smart licensing Mediated Model
https://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/212883-cucm-smart-licensing-mediated-model.html
Smart licensing Direct Model
https://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/212915-configure-cucm-smart-licensing-direct.html
PLM Guide
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/plm/11_5_1/userguide/CPLM_BK_CE0970F4_00_user-guide-rel-1151/CPLM_BK_CE0970F4_00_user-guide-rel-1151_chapter_0101.html
Highlighted
HI Nithin,
can we use  BE6k to deploy Meeting Server or should use separate instance?
Highlighted
The below link will give you more informations.
Virtualization for Cisco Meeting Server
https://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/uc_system/virtualization/virtualization-cisco-meeting-server.htmlScreen Shot 2020-08-12 at 3.32.46 PM.png
Highlighted
The maximum call supported depend  on the platform. so u should check your requirement and chose the right platform.  The below link will give you more informations.
Highlighted
Nithin,
what is the differnce in between these two products? Is there only number of ports difference and Both will be used for voice E1?
"2 Port Multiflex Trunk Voice/Channelized Data T1/E1 Module" Vs "4 Port Multiflex Trunk Voice/Clear-Channel Data T1/E1 Module".
Highlighted
Both cards support Voice.
In addition to the basic T1/E1 data support, the CE1T1 versions also support structured G.703 with G.704 framing and unstructured E1 (G.703) applications.
https://www.cisco.com/c/en/us/products/collateral/routers/4000-series-integrated-services-routers-isr/qa_c67-728823.html
Highlighted
Hi Nithin,
Hope you are fine.
I am looking a technical solution regarding ISDN/PRI-E1 configuration. i have two ISR -4431 on different locations. i am going to terminate 2x E1s on each router. but i want to segregate the out going calls as first call go out from 1st router's E1 and 2nd call should go out form 2nd router's E1. So for this purpose do you have any document or cvd which can help me out or any pre-configured document. please share.
Note: access code want to be remain same as "9" for all users.
Highlighted
