05-30-2017 06:34 AM - edited 03-17-2019 06:52 PM
User is trying to call forward his Jabber client on a MAC and it is saying "Call forwarding is disabled". Where do I fix that in CUCM?
05-31-2017 05:19 PM
Make sure you have a call forwarding CSS configured on the line configuration of the relevant device, check this first.
Please rate if useful
07-11-2022 06:30 AM
Did you find the solution for this. Coop1
07-12-2022 04:43 AM
Hi Coop1,
May i know what is the Jabber Client version being used, are you manually trying to add Call Forwarded Number on Jabber Client itself?
I am suspecting you might be Hitting Defect "CSCwb20855 "
Try configuring Call Forwarding Number from Self care portal and test.
Thanks & Regards,
Joy
