Highlighted
Beginner
Call option is not appearing on Jabber 10.5
Call option is not appearing on Jabber 10.5 .Need help if anyone faced this issue and how to resolve it
7 REPLIES 7
Highlighted
Hall of Fame Cisco Employee
Dis you properly configured the CSF device??? Also, do you have proper directory resolution???
java
if this helps, please rate
Highlighted
When i points this jabber client to the phone services in the settings , i can see the call option now .But when i point it to the presence it does not show call option . I am not using any SRV
Highlighted
I don't understand what you're doing, do you mean you use it in Full UC/softphone mode and then only in IM mode???
java
Highlighted
I want to use it in full UC/Softphone mode . So if i am not using SRV and i am manually pointing in the setting section of the jabber client . Should i point to Callmanager or Presence Server ?
Highlighted
That depends on the version you're using, and is thoroughly explained in the Jabber Deployment guide, have you reviewed it???
java
Highlighted
As earlier stated i am using 10.5 version . In the deployment guide it is not mentioned if you are not using srv records , where you should ideally points to if you want to use the full UC/Softphon mode . In the CVD it is mentioned to point to presence server .but for me i points to presence server , it doesnot show the call option in the jabber client but when i poins to cucm it shows both chat and call option.
Highlighted
It's the exact same thing, SRVs simply make it easier as you don't need to type in the info manually.
And as the guide explains, the difference relies on the UC version you're using, not the Jabber version. That's what I meant before.
java
Content for Community-Ad
