408
svadmin
Beginner
calls to agent in hunt group not forwarding to cellphone
I have setup a hunt pilot with ext 67809 and have so far only one user in the Line Group list.  I have the agents calls forwarded to his cellphone.
When I make a call to that ext 67809, the agent's main line ring, and doesn't forward to his cellphone.  in the Hunt Pilot configuration, for "Forward Hunt no answer" I selected "use forward setting of line group member"
not sure where else can this be control, can someone assist please
1 REPLY 1
Jaime Valencia
Hall of Fame Cisco Employee
That is working as designed, call forward settings are ignored if the call comes from a line group, either you use SNR, or forward directly in the hunt pilot.
java
if this helps, please rate
Create
Recognize Your Peers
Content for Community-Ad
