Can anyone please guide how to connect to jabber client using jabber web sdk?
chr.balaji
Unable to connect to the jabber web sdk and console log says that the plugin not available.
It seems the issue is with the browser plugin on an higher note.
Can anyone help me figure out what is the issue here?
Jaime Valencia
SDKs/APIs are covered in the developer network, you can try to post there, you might have better chances of getting assistance.
java
if this helps, please rate
