Working on CER 10.0 issue where it is not discovering individual (not stacked) 3650-48-PS model switch.
The CER 10.0 release notes (and 11.x, 12.x) list this model 3650 as supported with the same OID in 10, 11, and 12.x versions.
The OID for the Catalyst C3650-48PS (-L/S/E) is 1.3.6.1.4.1.9.1.1826. Same OID is listed in 10.x, 11.x, and 12.x CER release notes.
When I try to walk that OID from the CER server directly (utils snmp walk 2c) I get a generic error no response for OID. I can walk the snmp uptime OID fine. I also tried to walk the CER OID from snmp tools and nothing so it appears to not be a CER issue but somethingi on the 3650 not responding to that OID documented in CER release notes.
3650 IOS version is 16.3.6 IOS-XE Denali. Is there an issue with CER and newer Denali versions?
I found some other posts where people had issues with the old 3.6.x versions and going to 3.7.3 resolved them or going back to 3.3.3 did.
Thanks, Erick
