Cisco ATA190 with Fax over Sip trunk
mabuzaid1
Spoiler
Dear Community Team ,
Hope you all are doing well ,
This time i am facing a problem with FAX and the scnario as following :
Fax machine (HP all in one) to--- analog port of ATA 190 --SIP-- CUCM----SIP----CUBE----SIP----ITSP.
I have configured the ATA190 in CUCM and it's register with (Extension number 650) and seems to be registered properly .
So when I call the Fax number (phone call ) from PSTN to my network i hear a normal phone ring at my mobile.
But when i try to receive fax or send from / to network it fails (it says the number can't be dialed "cisco recorded message").
Here is my CUBE configuration :
(Please note that ITSP support G.711 dtmf-relay rtp-nte & T.38
voice service voip
ip address trusted list
ipv4 10.10.10.245 255.255.255.255
ipv4 10.189.16.X 255.255.255.255 (Cube interface with ITSP GW)
ipv4 10.189.16.x 255.255.255.255 (ITSP GW interface with CUBE)
ipv4 10.201.20.x 255.255.255.255 (SIP Server from ITSP)
no notify redirect ip2ip
mode border-element
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface GigabitEthernet0/0/0
bind media source-interface GigabitEthernet0/0/0
registrar server
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
translation-rule 1
rule 1 /011252.../ /650/ (our PSTN FAX number convert it to ATA extension  which is 650)
exit
voice tranalation profile PSTN-TO-CUCM
translate called 1
dial-peer voice 2 voip (incoming from STC)
transalte-profile incoming PSTN-TO-CUCM
Destintion-pattern .T
session protocol sipv2
session target ipv4:CUCM
session transport udp
voice-class codec 1
dtmf-relay rtp-nte
no vad
(Also outgoing configured well and all phones are working from/to PSTN except Toll free numbers).
Please help on this .
Mansour
nagaraj789
Try to connect Analog Phone to one of the ATA port and see if you can make or receive calls
Jorge Armijo M
Check your Voice dialing first, attach an analog phone to the ATA and make sure you can make.receive calls, then you can move to faxing.
Thanks nagaraj789 & Jorge Armijo M for your helpfull answers .
It was a dialing plan problem with CUCM .
Now it is working well .
I am having a very similar issue. We are able to make calls to and from the fax machine even. It just isnt sending the fax data or the fax machine gives us a poor line condition error. If anyone has any ideas help would be very nice. I do currently have a case open with TAC as well and our PSTN service provider.
