CMS recorder will only come in picture if any calls are hosted on CMS and then you can enable recording for space.
Multisite key is use when you wanted endpoint resources to host a conference.
If you have CMS then you can directly host your conference on CMS in place of endpoint and can record.
Please rate if it is helpful and mark as accepted solution if applicable....
