Cisco Jabber for android
haythamsaid
hi
where i can find the cop file for Jabber for android
5 Replies 5
Jaime Valencia
Step 1 Obtain the device COP file via your  Cisco account team.
a. Locate the Android device COP file.
b. Click Download Now.
c. Note the MD5 checksum. You will need  this later.
d. Click Proceed With  Download and follow the instructions.
Cisco Jabber for Android Release 8.6.x  Administration Guide
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cumc/cisco_jabber/Android/86/Cisco_Jabber_Android_8.6.x_Admin_Guide.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Hi  javalenc
Thanks for your reply
I downloaded this folder from cisco "cucimoc-Admin-ffr-8-0-3" and contains many folders. One of them named CUCM and has two files
1: ciscocm.installcsfdevicetype.cop
2: cmterm-cupc-dialrule-wizard-0.1.cop
is the file number 1 which i should to use  or what?
No, please carefully read what I posted.
This is not something that is publicly available, YOU NEED to go thru your Account Team to get this.
java
java
Thanks for your time
Kindly find  attahced images
This is right or wrong
