02-07-2014 04:43 PM - edited 03-17-2019 03:55 PM
what is required for cisco jabber for mobile devices to work.
we tested cisco jabber for windows desktop, it works when we connect through our sonicwall vpn.
i m testing for jabber android, what else is required for this to work?
for vpn connection through android phone, it is by sonicwall sslvpn.
will it work ?
Solved! Go to Solution.
02-09-2014 08:08 AM
Nothing different, just make sure you have proper device type defined correctly in CUCM for Jabber for Andorid device.
Chris
02-09-2014 08:08 AM
Chris
02-09-2014 05:59 PM
i am able to get connected now, after all the routing is enabled.
02-10-2014 05:57 AM
Great, is there anything else you need assistance with? If no please mark the thread as answered.
Chris
