10-18-2012 09:48 PM - edited 03-17-2019 02:42 PM
Dear All,
I am testing Cisco Jabber for Windows 9.0.4 on XenApp 6.5 environment, and I am facing issue that audio from Jabber to Physical phones is missing. But audio from Physical phone to Jabber is working.
On windows both microphone/speaker are working properly, but Jabber option Audio shows "Speaker is not found" and "Microphone is not found". Also I cannot change anything under Audio window.
I believe Jabber for Windows 9.0.x is supported on XenApp 6.5 environment.
Is there any way Jabber to recognize or change the configuration of Microphone and Speaker?
Also is anyone testing Jabber for Windows on XenApp environment?
Best regards,
YI
10-19-2012 04:30 AM
HI YI,
Is it XenApp 6.5 published Desktop or XenApp 6.5 published Application? Jabber only supports XenApp 6.5 published Desktop.
Maqsood
10-22-2012 12:21 AM
Hi Maqsood,
We are using XenApp 6.5 published desktop, and it should be supported.
Under Windows Control Panel, both microphone and speakers are working properly via XenApp. However Jabber option page does NOT recognize both (Citrix HDX Audio).
YI
11-02-2012 03:47 AM
Hi YI,
Please open a TAC case for further assistance.
Maqsood
11-23-2012 06:08 AM
Hi Yi
Did did you manage to get J4W to work in XenApp 6.5? I'm facing the same issue in J4W 9.1. I can't select headset in desktop mode.
Best regards
Kristian
12-07-2012 03:14 AM
Hi all,
we have the same problem. If a TAC case open on this?
There might already be a solution?
Kind regards
Chris
12-07-2012 06:07 AM
If everybody on this thread is referring to using Jabber on virtualized environment on SOFTPHONE mode, that's not supported.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
01-24-2013 06:42 AM
Now I'm trying to get J4W 9.1.2 and work on our stand-alone Citrix XenApp 6.5 servers. But I still can't select the headset in Audio menu. But the headset is showned in control panel. I'm running XenApp 6.5 in desktop mode.
Kristian
05-12-2013 09:02 AM
I have the same problem, tried up to Jabber 9.2.1 and still the same issut, one-way-audio on Xenapp 6.5 published desktops. The forwarded mic in Xenapp sends no audio to the remoteside.
In the audio recording and playback setting on xenapp desktop, I can see that both directions do react and another audio recorder is working.
When I login to the same Xenapp Server via MS RDP, the Jabber is working great.
any hint?
thx
Daniel
01-22-2014 02:47 AM
Jaime,
Sorry but unable to lacate your statement in the link you provided.
Has anyone got this working at all?
I have customer with same issue.
Neil
