368
Beginner
Cisco Jabber - Incoming Call Popup Location
Good afternoon all,
I'm currently using a twin monitor set up at work; and am having a little drama with Jabber and the popup.
When a call is coming through, the pop up window appears at the bottom right of the left hand screen (See screenshot)
Is there any way for me to move the pop up to the right screen? Due to my current desk setup, the bottom right hand corner of my left screen is hidden away, therefore I cannot physically see the pop up window.
Thanks muchly.
2 REPLIES 2
Highlighted
Hi Tye
Hi Tye
Strange behaviour, call toast always appear on the native screen. I just tested in my lab with windows release 11.7.1.  Which Jabber release are you running?
Tapan
Beginner
Good afternoon Tapan,
The company I work for is currently using 10.5.1.
I thought about just switching the screens over, but the stands I have wont fit on my desk properly if I did it.
Rock and a hard place I tell you.
Content for Community-Ad
August's Community Spotlight Awards
