Cisco Jabber login issue
SMK91
Hi Guys,
We are planned to migrate to Cisco Jabber from CIPC. And did the Installation part of the IM and Presence server and Jabber configurations in a Lab before go with the real setup.
We getting an error when we try to log into the jabber from users PC like,
Everything looks fine. But we are getting communication an error with the server like above image.
16 Replies 16
Are you using Manual configuration on Jabber ? or Automatic Discovery ?And why do you Use Cisco.local as you domain ?
You have shown NS lookup, but are you Abel to ping the imandp.cisco.local  from the pc ?
If automatic discovery, can you make sure that you have added the below SRV.
The following is an example of the _cisco-uds SRV record:
_cisco-uds._tcp.example.com SRV service location:
priority = 6
weight = 30
port = 8443
svr hostname = cucm.example.com
Response Signature
Hi Nithin,
Thank you for the reply.
Are you using Manual configuration on Jabber ? or Automatic Discovery? Manual Configuration
And why do you Use Cisco.local as your domain?  There is no special reason. This is the domain I have added when installing the server. Do I need to change it to something like .com or .net?
You have shown NS lookup, but are you able to ping the imandp.cisco.local from the pc? yes. I can
C:\Users\xxxxxxxxxx>ping 192.168.137.140
Pinging 192.168.137.140 with 32 bytes of data:
Reply from 192.168.137.140: bytes=32 time=1ms TTL=64
Reply from 192.168.137.140: bytes=32 time<1ms TTL=64
Ping statistics for 192.168.137.140:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 1ms, Average = 0ms
C:\Users\xxxxxxxxxx>ping imandp.cisco.local
Pinging imandp.cisco.local [192.168.137.140] with 32 bytes of data:
Any specific reason for why you plan to use manual configuration? That is really not recommend.
Normally you would use your own domain, not exactly what Cisco uses as the example in their documentation as it would look that you might have done.
Response Signature
Hi Roger,
It is getting error like,
" Cannot find your services automatically. Click Advanced settings to set up manually".
That's the reason.
To automatically discover the severs you need to create srv as mentioned in my previous reply.
Response Signature
I have added SRV record as you mentioned.
> set type=srv
> _cisco-uds._tcp.cisco.local
Server: UnKnown
Address: 192.168.137.150
_cisco-uds._tcp.cisco.local SRV service location:
priority = 6
weight = 30
port = 8443
svr hostname = imandp.cisco.local
imandp.cisco.local internet address = 192.168.137.140
Still, getting the same error like," Cannot find your services automatically. Click Advanced settings to set up manually".
svr hostname = cucm.example.com >> this should be your CUCM address not IM.
Address: 192.168.137.150 what's this address ?
If the user cannot login in to IM or Self care portal, check the roles assigned to the users. What roles you assigned to the users ? share the screenshot of user roles( bottom of the user page)
Response Signature
svr hostname = cucm.example.com >> this should be your CUCM address not IM.?
We don't have any domain name for CUCM. Do we need to create one?
These are the role that I have assigned to the user.
Address: 192.168.137.150 what's this address ?  The DNS server IP
What version fo CUCM  and IM are you using ? Make sure all services are running on Im.
I am not sure if we have option to configure the srv with ip on dns, if it doesn't support  ip you need to configure the domain for CUCM. and its a recommended to have domain configured on CUCM.
With the end user configurations shared, user should be able to login to the  selfceare portal and IM.
Response Signature
Control of all devices is not a recommended thing to grant all users.
Response Signature
That is because you have not created the needed SRV records for the service discovery, or your configuration is not correct.
Advice you to read the deployment guide for Jabber and verify that your setup is as such. https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/12_9/cjab_b_deploy-jabber-on-premises-129.html
Response Signature
Read the guide @Roger Kallberg shared and make sure that you done all require configurations.
Response Signature
Are you able to login to self care portal or Im  for this user   using username and password ?
what the user roles assigned for this user ?
Can you post manual configuration you did on jabber. @Roger Kallberg  mentioned manual is not much recommended since you are using in lab its okay.
Response Signature
Hi Nithin,
Are you able to login to self care portal or Im  for this user   using username and password ? Do I need to give access to each and every users who planned to use Jabber? This user cannot log into the IM server using his user name and password.
Can you post manual configuration you did on jabber. ?
