Walkthrough Wednesdays
351
ozden ozdugun
Beginner
cisco jabber problem
we have a cucm 8.6.2 but we couldn't find jabber version. which version of jabber supported cucm 8.6.2
3 REPLIES 3
Jaime Valencia
Hall of Fame Cisco Employee
That CUCM version is EOL/EOS, no current Jabber versions were tested with it, if you want full support, you need to upgrade your CUCM version, otherwise, you're free to try any Jabber version you like, but without any Cisco support or guarantee it will work properly.
java
if this helps, please rate
Vaijanath Sonvane
VIP Advocate
Cisco Jabber version 10.6 was supported with CUCM 8.6.2 or later. The newer versions 11.7 or later requires CUCM 9.x or later.
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
Hi vajianath
How can we download the old version jabber for android.and can we do this without im and presence ; and active directory
Content for Community-Ad
Spotlight Awards 2021
