cisco jabber problem
ozden ozdugun
we have a cucm 8.6.2 but we couldn't find jabber version. which version of jabber supported cucm 8.6.2
Jaime Valencia
That CUCM version is EOL/EOS, no current Jabber versions were tested with it, if you want full support, you need to upgrade your CUCM version, otherwise, you're free to try any Jabber version you like, but without any Cisco support or guarantee it will work properly.
java
if this helps, please rate
Vaijanath Sonvane
Cisco Jabber version 10.6 was supported with CUCM 8.6.2 or later. The newer versions 11.7 or later requires CUCM 9.x or later.
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
Hi vajianath
How can we download the old version jabber for android.and can we do this without im and presence ; and active directory
