11-14-2019 01:39 AM
we have a cucm 8.6.2 but we couldn't find jabber version. which version of jabber supported cucm 8.6.2
11-14-2019 07:09 AM
That CUCM version is EOL/EOS, no current Jabber versions were tested with it, if you want full support, you need to upgrade your CUCM version, otherwise, you're free to try any Jabber version you like, but without any Cisco support or guarantee it will work properly.
11-14-2019 07:15 AM
Cisco Jabber version 10.6 was supported with CUCM 8.6.2 or later. The newer versions 11.7 or later requires CUCM 9.x or later.
11-15-2019 01:15 AM
Hi vajianath
How can we download the old version jabber for android.and can we do this without im and presence ; and active directory
