Walkthrough Wednesdays
265
Highlighted
Participant
Cisco kit pro bandwidth consumption
Hello all ,
I would like to deploy cisco cms  in a headquarter , with cisco kit pro  in multisite over wan .
I would like to know how bandwidth consume this codec for the best use .
Best regards
Akram
4 REPLIES 4
Highlighted
Hall of Fame Cisco Employee
If you google: cisco kit pro bandwidth, you'll get the answer.
java
if this helps, please rate
Highlighted
Thank you for your answer, i know the consumption for this codec in point to point , but i need to know , how many bandwidth needed for a video conference with CMS .
Best regards
Highlighted
Then you probably want to provide a clear explanation of what you're looking for, CMS is mentioned nowhere in your original post.
That will depend on the quality of the video and approximates per video quality are in the SRND.
java
Highlighted
Collaborator
If you Google the Bandwidth for multi-site for the Codec, at this link : https://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/webex-room-series/datasheet-c78-741052.html
Under:
Performance features:
● Up to 15 Mbps total MultiSite bandwidth (6 Mbps in point-to-point calls)
In searching for CMS Bandwidth, I see two numbers that come up, 2.0 and 2.5 mbps:
https://www.ciscolive.com/c/dam/r/ciscolive/emea/docs/2018/pdf/BRKCOL-2803.pdf
https://www.cinos.net/wp-content/uploads/resources/cisco/cinos-cisco-meeting-server-datasheet.pdf
However, you can adjust the settings on the Meeting Server by going to the Configuration Menu and clicking on Call Settings or the URL/address of the CMS and adding /call_config.html to the end of the URL.
The Default in version 2.9.4 and 3.0 is 2.0 mbps. Please see the attached screenshots for more info.
I hope that helps.
Content for Community-Ad
