CMS Cluster - Active Calls Drop
ibrahim.kayali
Hello ,
We've 3 CMS in our cluster . In case of failover (CMS 1 go down) , the active calls on CMS 1 is dropping. CMS failover works for active calls or not ?
BR ,
Ibrahim.
prhobb
I suppose that it's normal.
This is already established call. CMS should to balance new calls only.
Correct, same behavior as if a SW/HW CFB was being used, if the bridge goes down, so does the call and you would need to dial in again, assuming the proper redundancy is configured to choose a working bridge.
If the call happens to be distributed, then those who are in the bridge that fails, goes down, etc. would be the only affected.
java
if this helps, please rate
