03-26-2018 01:37 PM - edited 03-17-2019 07:25 PM
Hi all,
I have a problem with my CMS Edge where if a guest points their browser to the URI, they don't get the 'Join call' landing page, they are taken straight to the 'Sign in' page.
We have a fairly standard Single Split server deployment. Everything else is working.
The annoying thing is this used to work. I don't know what happened to break it but I think it stopped working about the same time as our cert expired on the Webbridge. We got a new cert signed and uploaded and that part of it is now fine.
Any suggestions gratefully received.
B
03-26-2018 03:30 PM
Make sure the certificates have the right info and key usage, that the trust bundles are OK and that you established the trust with callbridge
03-27-2018 10:48 AM
As far as I can tell, all the certs are fine. Everything else is working and there are no cert warnings when I browse to the CMS Edge. It's just that we get the wrong landing page. Specifically, what cert might be causing this, if it is a cert issue?
