Contact Images and Click to Call in 9.6
Chris Pohlad-Thomas
So, I just upgraded from 9.2 to 9.6 and my contact images and click to call on a contact are gone. This was working with the previous version. Softphone and deskphone control work just fine. I do notice that instead of my name and photo up top it has my email (I am assuming that's my URI name). I've completely uninstalled and re-installed (it didn't seem to blow away any connection settings) and it doesn't help. Any thoughts on what to try next?
Chris
Chris Pohlad-Thomas
Does 9.6 only work with certain versions of CUIM&P? Once I dropped back to 9.2(6) it worked just fine. We are running 9.1.1.31900-1
Hi Chris,
Supported On-Premises servers are:
Cisco Jabber supports the following on-premises servers:
  • Cisco Unified Communications Manager version 8.0(1) or later
  • Cisco Unified Presence version 8.0(3) or later
  • Cisco Unity Connection version 8.5 or later
  • Cisco WebEx Meetings Server version 1.1 or later
For photo retrievla - please follow these instructions from Jabber Installation and Configuration guide.
If you still have problems after tihs - I would suggest you to contact TAC.
Nebojsa
