CUBE One-Way Audio
3MAD
Dears, hope you all doing well,
We have this environment (call flow):
ITSP (SIP Trunk) --> CUBE --> CUCM (5001 is AA) --> CUC (Customer Service 0 is a hunt group on CUCM extension number 1888)
We have one way-audio and the call will disconnect after 10-15 seconds when calling to this hunt-group, the weird thing is when I do a "debug ccsip messages" the call will work fine
This is the running config on my CUBE
voice-card 0
 dspfarm
 dsp services dspfarm
voice rtp send-recv
voice service voip
 ip address trusted list
  ipv4 172.25.227.29 255.255.255.255
  ipv4 10.141.40.233 255.255.255.255
  ipv4 10.170.16.69 255.255.255.255
 mode border-element
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 signaling forward unconditional
 fax protocol pass-through g711alaw
 sip
  early-offer forced
  no call service stop
voice class codec 1
 codec preference 1 g711alaw
 codec preference 2 g711ulaw
 codec preference 3 g729r8
 codec preference 4 g729br8
voice class dualtone-detect-params 1
 freq-max-power 0
 freq-min-power 13
 freq-power-twist 4
 cadence-variation 8
voice class e164-pattern-map 1
 description ##ALL INCOMING NUMBERS FROM STC##
  e164 ^01142087..
  e164 ^42087..
voice class e164-pattern-map 2
 description ##INCOMING NUMBERS FROM CUCM##
  e164 ^01142087..
  e164 ^42087..
voice class server-group 1
 ipv4 172.25.227.29 preference 1
 description ##CUCM##
voice translation-rule 2
 rule 1 /^.*/ /5001/
voice translation-rule 4
 rule 1 /^9/ //
voice translation-profile IN-FROM-STC
translate called 2
voice translation-profile OUT-TO-STC
translate called 4
interface GigabitEthernet0/0
 description ## LAN ##
 ip address 172.25.227.126 255.255.255.0
 duplex auto
 speed auto
interface GigabitEthernet0/2
 description ## STC_SIP_CIRCUIT ##
 ip address 10.170.16.70 255.255.255.252
 duplex auto
 speed auto
no ip http server
no ip http secure-server
ip route 10.141.40.233 255.255.255.255 10.170.16.69
ip ssh version 2
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dspfarm profile 1 transcode universal
 codec g729abr8
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 codec g729r8
 codec g722-64
 maximum sessions 10
 associate application CUBE
dial-peer voice 1 voip
 description ##ALL INCOMING NUMBERS FROM ITSP##
 translation-profile incoming IN-FROM-STC
 session protocol sipv2
 session target ipv4:172.25.227.29
 session transport udp
 incoming called e164-pattern-map 1
 voice-class codec 1
 voice-class sip bind control source-interface GigabitEthernet0/2
 voice-class sip bind media source-interface GigabitEthernet0/2
 dtmf-relay rtp-nte sip-kpml
 no fax-relay sg3-to-g3
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 no vad
dial-peer voice 2 voip
 description ##TO CUCM##
 destination-pattern 5001
 session server-group 1
 voice-class codec 1
 voice-class sip bind control source-interface GigabitEthernet0/0
 voice-class sip bind media source-interface GigabitEthernet0/0
 fax-relay ecm disable
 no vad
dial-peer voice 3 voip
 description ##ALL INCOMING NUMBERS FROM CUCM##
 incoming calling e164-pattern-map 2
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
dial-peer voice 4 voip
 description ## OUTGOING CALL TO ITSP##
 translation-profile outgoing OUT-TO-STC
 destination-pattern 9T
 session target ipv4:10.141.40.233
 voice-class codec 1 offer-all
 voice-class sip early-offer forced
 dtmf-relay rtp-nte cisco-rtp h245-alphanumeric h245-signal sip-kpml sip-notify
 no vad
Thanks in advance
16 Replies 16
That’s awesome. Thanks for the feedback that it’s working for you now. Glad to be able to help you out.
Response Signature
Thanks again Roger, you're the best :)
