CUCM-IMP 12.5SU1 cisco sync Agent stuck on starting
shloki193
Hi all
cucm 12.5su1
cucm-imp 12.5su1
IMP Sync agent seems to be stuck on starting and than stopped in the PUBLISHER node
- i have restarted the server - didn't help
- i have reinstalled the server - didn't help
- found many different Bugs regarding this issue in other versions - but no on mine -tried them ALL - didn't help
Did anyone had this issue in this versions ?
6 Replies 6
Anthony Holloway
Here you go: https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvg76031
My own summary of the workaround/solution:
SSH into the node with the stuck services and run this command:
set replication-sync monitor disable
Then run and wait for a loooong time for all services to show STARTED:
utils service restart Service Manager
Once all service show started (if this actually fixed your issue), then run this command:
set replication-sync monitor enable
To revert your change.
Thanks for your Quick Reply
Tried It with no Success
Any Ideas ??
TAC case?
thanks. solved my problem.
thanks for this info, fixed my problem.  I did not have to wait that long, maybe 5 minutes.
i have the same issue, after deleting IMP from CUCM and adding it again the sync agent is not able to run. what did you do ?
