CUMP 8.5 - Any Way to Monitor Current SRU Utilizaiton?
Michael Mertens
We're in the pilot/test phase of a global MeetingPlace 8.5 deployment and would like to monitor node capacity utilization to see if I might need to add more to my cluster in my region. Is there a way for me to monitor SRU Utilization to see if I'm getting near node capacity as meeting attendees join?
THANKS!
Mike.
Derek Johnson
Hi Mike,
You can use the mbdstatus command, which usually takes a few seconds to update. Look for the
'UsedAudio =' which represents the SRU usage reported to the primary MBD. There are some other commands and details about them here:
http://www.cisco.com/en/US/docs/voice_ip_comm/meetingplace/8_5/english/administration/cli_application_server.html
Derek Johnson
Conferencing TAC
As always- thanks Derek!
