Cups call feature unavailable
mamemor.diagne
Hello Community,
I install cups 8.5.1-10000-26 with cucm 8.5.1-11900-21. My ldap integration with cups work, i can search and find contact on jabber, send and receive text with chat but impossible to place call because call feature appears but not unavailable.
Need help
Mame Mor DIAGNE - FRANCE
Sent from Cisco Technical Support Android App
Jaime Valencia
Have you created the CSF device and correctly associated it to the user/device/line??
If not, review either the CUPC/Jabber admin guides to do such task.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
mamemor.diagne
csf is created on my cucm and associated to my end user as a controlled device like udp....
But my jabber/device is not registred always can see unknow/unknow from cucm. After open jabber client under window i have an icon and 2 choice
1 - use my compture for call
2 - or use my phone for call.
After adding csf i can see new feature video avalaible under options/video.
But cant place call always.....
mamemor.diagne
Thanks, it working !
Just follow your idea and my problem is solve.
