CWMS 2.0 SSO using Shibboleth
Lee Pipkin
Level 4
Level 4
Has anyone using CWMS 2.0 successfully configured SSO with open source Shibboleth? If so can you give some insight on the configs?  We have it to the point that our CWMS is not accepting the SAML assertions being to it from our IdP.
keglass
Level 7
Level 7
I recommend you also post this to the Cisco Support Forum to receive additional feedback and information.
Cisco Technical Support Forum
Thank you for participating in the community.
Kelli Glass
Moderator for the Cisco Collaboration Community
Did you ever find a resolution to this?  Looking at a similar integration.
The customer was able to get it working, but I think you realize that Shibboleth is not a TAC supported IDP.   Perhaps they will comment.   They had to make some changes on their Shibboleth server to get this to work.
