Walkthrough Wednesdays
1504
CWMS call-in drop after meeting-ID entered
Dear all,
we have webex 2.6.1.45.B-AE, call out working, but call-in drop after meeting-ID entered...DTMF working.
can be, because:You are using a trial version of Cisco WebEx Meetings Server that expires in 32 days. Purchase host licenses for your system to avoid limiting host access?
or anyone have any idea?
Thanks a lot!
1 ACCEPTED SOLUTION
dpetrovi
This issue is caused by misconfiguration of CUCM integration with CWMS.
Make sure you check you SIP Trunks and SIP Route Pattern configuration on CUCM.
Make sure your SIP Route Pattern points to Application Point SIP trunk.
Make sure that the Partition configured in SIP Route Pattern belongs to a CSS that is configured in LoadBalancing SIP trunk under:
1. Rerouting Calling Search Space
2. Out-Of-Dialog Refer Calling Search Space
Also, reference this post to understand why SIP Route Pattern and Application Point SIP trunks are used: https://supportforums.cisco.com/discussion/12879351/cucm-and-cwms-call-routing
Also, reference this official documentation guide: http://www.cisco.com/c/en/us/td/docs/collaboration/CWMS/2_6/Planning_Guide/Planning_Guide/Planning_Guide_chapter_0101.html
I hope this will help.
-Dejan
2 REPLIES 2
dpetrovi
-Dejan
Hi Dejan,
thank you, rerouting CSS was the solution.
Content for Community-Ad
Spotlight Awards 2021
